Extra line buttons
Discussion in '3CX Phone System - General' started by jparisi, Oct 1, 2007.
  1. jparisi
    Oct 1, 2007
    92
    Is there any standard practice on what to do with the extra line buttons that are on some phones? For example, the Linksys 942 and Polycom 501?
    The only thing I can see is to assign them as extensions. Should they all be assigned the same extension?
    Thanks,
