Extract a DID from Caller Name
Discussion in '3CX Phone System - General' started by 0906794, May 2, 2017.
    May 4, 2012
    My VOIP provider can not send the inbound DID in the SIP:To field. He is able to prepend it to the Display info field in the SIP:From Information . I cannot find a way to get 3CX to use this field. Only the User Part.
    Any work abounds available.
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @0906794,
    What does your provider send to the "TO" field? Is it just blank?
    I would recommend to move to a supported SIP provider.
  3. 0906794
    May 4, 2012
    Finally figured it out. Needed to adjust my inbound parameters and mapped my Display field to the From field. At that point I changed from DID to CID and set the mask accordingly. Makes a mess of my CID display on the phone but it is not used.
