extrnal ext
Discussion in '3CX Phone System - General' started by sata, Jul 24, 2007.
  1. sata
    Jul 16, 2007
    22
    hi i am looking to set up a external ext do i dose the external ext have to have a static public ip address ? i am havein some problems i have a fire wall but that is connected to a bt broadband router ?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    3CX box can support external extension without static public IP.
    - Need to have STUN server correct config
    - Tick "Bind to Media Server"
    - Tick "Extension is external"
    Open these ports on your firewall or Broadband router:
    5060 port forward to 3cx box
    9000-9003 udp port forward to 3cx box
    9000-9003 udp allow any IP to any IP for in and out
    3478 udp allow any IP to any IP for in and out
  3. nahidul
    Jul 9, 2007
    28
    Hello.
    I need help setting up external Extensions and the D-Link router firewall. Could anyone help me and let me know what I am doing wrong in firewall setup please. See - http://people.stu.ca/~nahid/others/3cx/D-Link_DI524_Firewall.pdf .
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Keywords - full cone NAT
    It will work like a charm.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi nahidul,
    Your 3cx box already put into the DMZ. It should be no need to do the ports forward. If it still not works. Please provide the 3cx log
  6. nahidul
    Jul 9, 2007
    28
    Hello.
    Please see http://people.stu.ca/~nahid/others/3cx/3CX_Log_18July2007.pdf or http://www.3cx.com/forums/viewtopic.php?t=1763 .
    Thank you in advance for your help.
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please try to use STUN server 80.239.235.209 for your Virtual Extension 10000@Acanca instead of 66.7.238.210
  8. Anonymous
    Anonymous Guest
    I've followed your directions for configuring a firewall for external extension
    When I dial the extension, I hear no audio and this is what the server log shows:
    [MS101003] Call(183) Ext.107: Possible firewall problem. Address mapping failed on STUN server 69.0.208.27:3478 for local address ":9002"
    Any suggestions?
    Brian
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi bfleishman,
    Apologies for my over look
    Which firewall are you in use (brand and model)?
    Please try to temporary allow UDP any any form WAN in and out to the box's IP. Then refer to the firewall log, it may be help to solve this issue.
    Regards
  10. SY
    3CX Support
    Jan 26, 2007
    1,825
    please forward ports in both directions it mean that outgoing packets from PBXhost:port[9000-9003] also must be sent outside from ports 9000-9003 of the NAT host.
    Stepan
