Fail - Apple Push Notifications in 3CX Management Console ?
Discussion in '3CX Phone System - General' started by a6ela, Feb 23, 2017.
Tags:
  1. a6ela
    Feb 23, 2017
    Morning All,
    I'm currently new to 3CX and having a little bit of a issue trying to work out how to setup "Apple push notifications". If I go by what is written in the manual (www.3cx.com/docs/configuring-apple-push/). I can not work out what they are saying.
    We are running v15, and the layout has changed. So when I log into the Management console, I go to settings (on the left side) then click on "3CXphone".
    I can see where we can setup "google push", but where is the box that allows me to tick enable apple push?
    any help would be greatly appreciated.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    Apple push should just work... out of the box... as long as it is enabled for the particular extension.
    And, your firewall has these ports open - OUTBOUND: Port 2195, 2196 (outbound, TCP) for Apple iOS Push
    Notice the link you refer to clearly says on the first line: This guide applies only for 3CX Phone System 12 and 12.5.
  3. a6ela
    Feb 23, 2017
    Thanks for the reply Craig, I have had a look at the users extension options, what am i looking for to "enable" it?
  4. craigreilly
    Feb 1, 2012
    3,321
    252
    Open an Extension
    goto the phone provisioning tab
    chaneg the dropdown from "Yealink (or other)" to 3cx Client.
    Enable Push for Smartphone
  5. a6ela
    Feb 23, 2017
    Thanks again for the reply.
    All these settings you have told me about are already setup on our server.
    Maybe I have asked the wrong question before, here is my true problem.
    Staff have iPhones (mostly running ios10.x) when they are OUT of the app, and doing other things on the phone or the phone screen is off, 3CX does not work. I thought that the "push" option should allow them to use 3CX with out the application be open on the screen. Am i right saying this? or 3CX ONLY works when the app is open??
    cheers
  6. craigreilly
    Feb 1, 2012
    3,321
    252
    I thought you were having issues with setup. You have done all that. So, onto diagnostics.
    It should always work - and seems to work for me...
    I just tested mine and it did just that.
    Client: 15.2.5.138 (beta)
    Verizon LTE
    Perhaps a Wireshark on the server would ensure the push is actually going out... I am going to do some more tests here.
    What are your clients on - WiFi or Cell? Carrier?
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @a6ela
    On the update section on the top of the the update section make sure that under "other" there is no IOS certificate waiting to be installed.
    If there is one there then install it and then send new welcome emails to your IOS devices.
    Also make sure that in the iPhones notifications for the 3CX app are allowed.
