Fail-over questions
Discussion in '3CX Phone System - General' started by schut, Jan 16, 2017.
  1. schut
    Jul 30, 2012
    22
    We're considering a 3CX Fail-over in our office but reading about it a couple of questions arise on what is needed:
    * I see you need a "full" additional license for the backup/fail-over server. Can this license contain less concurrent calls? e.g. Main server has 64 simultaneous calls, can the backup have "only" 32?
    * The backup runs on another IP, I reckon you need special phones which have a fail-over system for automatically connecting to the secondary server with a different IP, or do you need to provision the phones (again) ?
    * How do gateways handle an IP-change?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello there,
    You only need one Enterprise License for failover and it will be used for both installations as the config can only be active-passive.
    To use failover you must have an internal DNS you can handle and specify this upon installation. You must configure the PBX to use split DNS so internally the FQDN must resolve on your local IP of the PBX. Once the failover starts the DNS entry will be re-writen to point to the new IP.
    Gateways are not supported for failover, you can only use SIP providers.
    Read through the following article as it contains more information regarding how failover works
    http://www.3cx.com/docs/failover/
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Little outside of my scope, but in edition comparison I see there is Inbuilt Fail Over also in Pro edition?:confused:
    • Upgrade 1 license from Standard/Pro to Enterprise
    • Use 2 Pro
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Failover works with pro too but there is a high possibility to reach the mac activation limit on the license.
    Enterprise license is designed for failover.
    and you still only need one license with pro.
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Thanks, but there is again confusion with edition compare table?
  6. npereira@cbnco.com
    Sep 21, 2012
    32
    11
    hmmm.... im also looking at this for a 256 Enterprise license.
    you just made me aware that the failover does not work for Gateways? Im not sure I agree with this unless there is soemthing im missing, but if the gateways register to the 3CX using the DNS name instead of IP, as soon as the DNS updates the gateway should re-registering to the new system.
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    If your gateways can register using the hostname then in theory this might work. this is not something we tested however and cannot guarantee this will work
