failed bridge call
Discussion in '3CX Phone System - General' started by craigreilly, Aug 13, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    Can anyone make sense of this? It is a call from Main Office to Remote Office via Bridge. The link is up. I see on the remote end the call coming in briefly on the Trunk Status page. My call gets a busy signal. The log shows Terminated. The Bridge is SLAVE-Direct-UDP to our Corporate Office (Master).
    Call is made from me 4954 to 15512. 155 signifies the bridge to use. It is stripped and 12 is the extension I called. In the log, 480-596-xxxx is my outbound caller id (I think for the extension makiing the call).
    10.0.1.100 is the remote pbx running the 8 call version.
    10.0.1.248 is Extension 11 on Remote PBX.
    Code:
    13-08-2012 09:20:10.678	Leg L:13.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.0.1.248:5060
    13-08-2012 09:20:10.677	[CM503003]: Call(C:13): Call to <sip:12@10.0.1.100:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.0.1.248:5060
    13-08-2012 09:20:10.488	Leg L:13.1[Line:10155<<480596xxxx] is terminated: Cause: 200 BYE from PBX
    13-08-2012 09:20:10.437	[CM503020]: Call(C:13): Normal call termination. Call originator: Line:10155<<480596xxxx. Reason: [color=#FF0000]Forbidden[/color]
    13-08-2012 09:20:10.437	[CM503016]: Call(C:13): Attempt to reach <sip:12@10.0.1.100:5060> from Line:10155<<480596xxxx has failed. Reason: [color=#FF0000]Forbidden[/color]
    13-08-2012 09:20:10.437	Leg L:13.2[Extn] is terminated: Cause: 603 Decline/INVITE from 10.0.1.249:5060
    13-08-2012 09:20:10.436	[CM503003]: Call(C:13): Call to <sip:12@10.0.1.100:5060> has failed; Cause: 603 Decline/INVITE from 10.0.1.249:5060
    13-08-2012 09:20:10.255	[CM503025]: Call(C:13): Calling T:Extn:12@[Dev:sip:12@10.0.1.249:5060;transport=udp,Dev:sip:12@10.0.1.248:5060;transport=udp]
    13-08-2012 09:20:10.248	[CM503025]: Call(C:13): Calling T:Extn:12@[Dev:sip:12@10.0.1.249:5060;transport=udp,Dev:sip:12@10.0.1.248:5060;transport=udp]
    13-08-2012 09:20:10.225	[CM503027]: Call(C:13): From: Line:10155<<480596xxxx ("Craig Reilly" <sip:480596xxxx@10.0.1.100:5060>)  to  T:Extn:12@[Dev:sip:12@10.0.1.249:5060;transport=udp,Dev:sip:12@10.0.1.248:5060;transport=udp]
    13-08-2012 09:20:10.225	[CM503004]: Call(C:13): Route 1: T:Extn:12@[Dev:sip:12@10.0.1.249:5060;transport=udp,Dev:sip:12@10.0.1.248:5060;transport=udp]
    13-08-2012 09:20:10.223	[CM503001]: Call(C:13): Incoming call from Line:10155<<480596xxxx to <sip:12@10.0.1.100:5060>
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    How are the 2 office physically connected?
    I am a little confused with "Decline/INVITE from 10.0.1.249:5060"
    You appear to be running the same LAN nets on both sites.
  3. craigreilly
    Feb 1, 2012
    2,947
    179
    Both are physically separate networks. No VPN or anything.
    Site 1: Main Office: 10.0.0.1-10.0.3.254
    Site 2: Remote Office: 10.0.1.1-10.0.1.254
    10.0.1.249 is the phone I was calling to.
    Would that cause an issue? Should I change their network scheme?
  4. craigreilly
    Feb 1, 2012
    2,947
    179
    Well I changed the scope of the rmeote site. changed out the router that had issues.
    Still 1 way audio.
    Then they told me when it started happening.
    I was here on Friday and the phones weren't getting an IP Address. So, I stuck a 169 address into the server (in addition to the 10.x) to program the phones and that seemed to be the culprit.
    Doh!
    :eek:
  5. lneblett
    Sep 7, 2010
    2,061
    56
    Knew you would figure it out.
