Failed Installation
Discussion in '3CX Phone System - General' started by markf100, Jun 11, 2017.
  1. markf100
    Jun 11, 2017
    15
    Installed on remote VPS, using your FQDN + Letsencrypt, provided all the details, ensured ports were forwarded as per documentation, set https to 443 and http to 80 and then receive the following error:
    System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) ---> Npgsql.PostgresException: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) at Npgsql.NpgsqlConnector.DoReadMessage(DataRowLoadingMode dataRowLoadingMode, Boolean isPrependedMessage) at Npgsql.NpgsqlConnector.ReadMessageWithPrepended(DataRowLoadingMode dataRowLoadingMode) at Npgsql.NpgsqlDataReader.NextResultInternal() at Npgsql.NpgsqlDataReader.NextResult() at Npgsql.NpgsqlCommand.Execute(CommandBehavior behavior) at Npgsql.NpgsqlCommand.ExecuteScalarInternal() at PostInstall.DBConnection.ExecuteScriptInternal(NpgsqlConnection connection, String sqlQuery, IDictionary`2 parameters) at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged, Action`1 errorNotifier) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
    Can you help, tried multiple installs about to give up an use another product.
    Thank you.
    Mark
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @markf100
    Please make sure you have a backup of your installation (if any) to a secure location and un-install the PBX. Then run the following commands restart the machine and try installing again.
    Code:
    sudo apt-get purge locales
    sudo apt-get install locales
    sudo dpkg-reconfigure locales
    en_US.UTF-8
    Let us know if that works for you
