Failed Registration -Linksys SPA3102 -as a PSTN Gateway
Discussion in '3CX Phone System - General' started by noddy184, Oct 10, 2012.
  1. noddy184
    Aug 16, 2012
    22
    Hey Guys
    RE SPA3102 - Failed Registration / Will not Register with PBX
    I have purchased a new SPA3102 to use as a PSTN Gateway (I want callers to be able to ring my PSTN phone number and the SPA3102 answer the call and put it into the PBX). Did a reset to factory , then configured it exactly as this guide has said to:
    http ://www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
    Anticipating a faulty unit or overlooked setting, i got a second SPA3102 and performed the same config, which results in the same problem. Maybe it's my 3CX config?
    IP of 3CX = 192.168.2.2
    IP of SPA3102 = 192.168.1.6
    One query - my PBX is on port SIP 5062 but the setup on the SPA3102 is for SIP 5062 - is it meant to be the same port?
    Have attached screenshots but can provide others if needed.
    Could I have some suggestions as to what i have done wrong?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    see this article, maybe will help
    http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE
  3. noddy184
    Aug 16, 2012
    22
    hi mixig
    already followed the guide closely, still errors hence posting.
  4. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Hi again,
    in your post you said that ip of 3cx is 192.168.2.2 and in linksys you put 192.168.1.2??
  5. noddy184
    Aug 16, 2012
    22
    correction.. sorry to clarify the IP is 192.168.1.2 for the PBX
  6. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Does the 3CX server log (event or activity) show any communications attempt at a registration? You might also check for black listing as I guess it possible that when initially setting-up possibly the credentials were not fully established and the registrations failed x # of times and the SPA IP was subsequently blacklisted.
  7. leejor
    10,368
    228
    A few things that need to be changed...
    PSTN ring thru line 1, set to NO
    Change PSTN CID for VoIP CID to YES
    Dial Plan 8 should be (S0<:10002>)
    Register Expires can be set to 1800 (360 is a bit too short)
    You'll probably want to set PSTN Answer Delay to 3 or 4, 16 seconds is too long to wait for the call to be passed to 3CX.
    Use a more secure password.
    In the Info tab, you have Line 1 status circled, it's the PSTN Status you are currently working on.
    Are you using the correct Ethernet port on the 3102? It should be the blue one (Internet) as it appears the you still have the router function enabled in the 3102.
    Don't let the port numbers confuse you. By default, 3CX will listen on port 5060, that is the default port that the 3102 will send to. You have set the PSTN portion of the 3102 to listen on port 5062 and put that same port number in the trunk settings in 3CX.
  8. noddy184
    Aug 16, 2012
    22
    Ok guys I have figured out the problem, I had incorrect authentication in the PSTN gateway settings , - so I deleted the gateway and readded it, all working. The log reveals all! Thanks for the tip.
    My next problem is that the SPA3102 is not putting the inbound calls from the PSTN through to the 3CX PBX properly.
    When I ring the PSTN number, the SPA3102 answers the call after 3 secs (as it's meant to) but then you get a (internal) dial tone. (the same noise as if you'd picked up a handset connected to the PBX and it waits for you to dial your number). After a few seconds it times out.
    I rang the PSTN number again, waited for the dialtone, and this time I key'd in an extension number (once I heard the 3cx dial tone). It than transfers the call to the ring group I assigned in 3CX and the call connects successfully.
    How can I get it (PSTN) to just connect staight to the ring group without the inbound caller having to do anything or push any numbers on his phone?
  9. leejor
    10,368
    228
    Sorry, I think I missed something too. Did you change the PSTN caller default DP to "8" to make use of the "forward" rule (S0:<10002>) in there.
    You may also want to consider upgrading the firmware. Latest is 5.2.13
    Download...
    http://www.cisco.com/cisco/software/release.html?mdfid=282414112&softwareid=282463187&release=5.2.13&relind=AVAILABLE&rellifecycle=&reltype=latest
    Instructions...
    http://www.cisco.com/en/US/products/ps10024/products_qanda_item09186a0080a35f1e.shtml?referring_site=smartnavRD
    All settings remain intact after an upgrade.
  10. noddy184
    Aug 16, 2012
    22
    Leejor, you're the man, it's all working now, just had to change the PSTN caller default dp to 8. i tried to upgrade the firmware but it error'd out, will try that another time.
    However PSTN inbound calls now work, goes straight into the PBX.
    Thanks for your help... legendary. :D
