GNU nano 1.3.12 File: asterisk/manager.conf
; AMI - Asterisk Manager interface
; FreePBX needs this to be enabled. Note that if you enable it on a different IP, you need
; to assure that this can't be reached from un-authorized hosts with the ACL settings (permit/deny).
; Also, remember to configure non-default port or IP-addresses in amportal.conf.
; The AMI connection is used both by the portal and the operator's panel in FreePBX.
; FreePBX assumes an AMI connection to localhost:5038 by default.
[general]
enabled = yes
port = 5038
bindaddr = 127.0.0.1
displayconnects=no ;only effects 1.6+
[admin]
secret = 12345678
deny=0.0.0.0/0.0.0.0
permit=127.0.0.1/255.255.255.0
read = system,call,log,verbose,command,agent,user,config,command,dtmf,reporting,cdr,dialplan,originate
write = system,call,log,verbose,command,agent,user,config,command,dtmf,reporting,cdr,dialplan,originate
#include manager_additional.conf
#include manager_custom.conf
GNU nano 1.3.12 File: amportal.conf
# This file is part of FreePBX.
# FreePBX is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 2 of the License, or
# (at your option) any later version.
# FreePBX is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with FreePBX. If not, see <http://www.gnu.org/licenses/>.
# This file contains settings for components of the Asterisk Management Portal
# Spaces are not allowed!
# Run /usr/src/AMP/apply_conf.sh after making changes to this file
# FreePBX Database configuration
# AMPDBHOST: Hostname where the FreePBX database resides
# AMPDBENGINE: Engine hosting the FreePBX database (e.g. mysql)
# AMPDBNAME: Name of the FreePBX database (e.g. asterisk)
# AMPDBUSER: Username used to connect to the FreePBX database
# AMPDBPASS: Password for AMPDBUSER (above)
# AMPENGINE: Telephony backend engine (e.g. asterisk)
# AMPMGRUSER: Username to access the Asterisk Manager Interface
# AMPMGRPASS: Password for AMPMGRUSER
AMPDBHOST=localhost
AMPDBENGINE=mysql
# AMPDBNAME=asterisk
AMPDBENGINE=mysql
AMPDBUSER=asteriskuser
# AMPDBPASS=amp109
AMPDBPASS=99pir3208
AMPENGINE=asterisk
AMPMGRUSER=admin
#AMPMGRPASS=amp111
AMPMGRPASS=12345678
# AMPBIN: Location of the FreePBX command line scripts
# AMPSBIN: Location of (root) command line scripts
AMPBIN=/var/lib/asterisk/bin
AMPSBIN=/usr/local/sbin
# AMPWEBROOT: Path to Apache's webroot (leave off trailing slash)
# AMPCGIBIN: Path to Apache's cgi-bin dir (leave off trailing slash)
# AMPWEBADDRESS: The IP address or host name used to access the AMP web admin
AMPWEBROOT=/var/www/html
AMPCGIBIN=/var/www/cgi-bin
# AMPWEBADDRESS=x.x.x.x|hostname
# FOPWEBROOT: Path to the Flash Operator Panel webroot (leave off trailing slash)
# FOPPASSWORD: Password for performing transfers and hangups in the Flash Operator Panel
# FOPRUN: Set to true if you want FOP started by freepbx_engine (amportal_start), false otherwise
# FOPDISABLE: Set to true to disable FOP in interface and retrieve_conf. Useful for sqlite3
# or if you don't want FOP.
#FOPRUN=true
FOPWEBROOT=/var/www/html/panel
[ Read 284 lines ]
