Failed to establish connection to 3cx phone system web api
Discussion in 'Windows' started by ummara, Jan 22, 2016.
  1. ummara
    Jan 21, 2016
    On start of 3cx phone, it gives,"failed to establish connection to 3cx phone system web api"
    and contacts and status in "presence " are not available.
    I configured spilt dns and have done configuration of external and internal FQDN.
      File size:
      25.8 KB
      1,094
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    Check out this thread, I think the problem might be very similar:
    http://www.3cx.com/forums/viewtopic.php?f=34&t=43819
  3. aktivtrans.cz
    Jan 24, 2016
    HEllo, I have same issue. Failed to establish connection to 3cx phone system web api.
    Your thread was helped...
    this..
    Postby oakley » Mon Jan 18, 2016 10:26 am
    I found that the system settings can be changed in the server manager in troubleshooting/parameters. I changed all the external parameters to the correct external ip and opened ports 5000 and 5001 on the firewall. I then sent the welcome emails again and all the devices are now working!
    Thanks for your help as looking thru the welcome email in a text editor showed where the issue was :)
  4. ummara
    Jan 21, 2016
    Thanx.Problem solved by sending the welcome mail
