Solved Failed to start 3CX PhoneSystem 01 SIP Server. Core dumped
Discussion in '3CX Phone System - General' started by EvilX, Mar 22, 2018.
  1. EvilX
    Mar 22, 2018
    Hi there.
    I installed the 3cx instance with iso to real server.
    After installation and base configuration sip service did't start.
    Whats wrong?
    Syslog:
    Mar 23 01:17:56 local systemd[1]: Starting 3CX PhoneSystem 01 SIP Server...
    Mar 23 01:17:56 local kernel: [ 31.292250] 3CXPhoneSystem[867]: segfault at 0 ip 000000000051725b sp 00007ffcb9fd6120 error 4 in 3CXPhoneSystem[400000+3c7000]
    Mar 23 01:17:56 local systemd[1]: 3CXPhoneSystem01.service: Main process exited, code=dumped, status=11/SEGV
    Mar 23 01:17:56 local systemd[1]: Failed to start 3CX PhoneSystem 01 SIP Server.
    Mar 23 01:17:56 local systemd[1]: 3CXPhoneSystem01.service: Unit entered failed state.
    Mar 23 01:17:56 local systemd[1]: 3CXPhoneSystem01.service: Failed with result 'core-dump'.
  2. EvilX
    Mar 22, 2018
    I found the reason - tun interface.
    I dont know why. After I stoped openvpn service - 3CX started.
    Any one know, how to fix it? I need openvpn connection to that server.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,452
    541
