Failing Install v10 on Win2008R2 - SP1 **Solved
Discussion in '3CX Phone System - General' started by StewartGilray, Jun 6, 2011.
  1. StewartGilray
    Jun 6, 2011
    11
    I'm trying to do a v9 to v10 upgrade.
    I've followed the uninstall instructions for V9 (after a backup), and am now trying to install v10, however I am getting the same error EVERY time I run the installer ...
    "Error writing to file: FCGIDotNet_4_0_x64.exe. Verify that you have access to that directory."
    Retry/Cancel
    Upon clicking retry I get...
    "FDI Server error"
    Retry/Cancel
    When I click retry I then get ...
    "The file 'FCGIDotNet_4_0_x64.exe' cannot be install because the file cannot be found in the cabinet file 'disk1.cab'. This could indicate a network error, an error reading the CD-ROM, or a problem with this package."
    Any ideas?
    Thanks in advance.
    Stewart
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: Failing Install v10 on Win2008R2 - SP1
    Please download 3CX phonesystem on your desktop and then run again. You are trying to run/install 3cxphonesystem without downloading the .exe setup file, am I correct?
  3. StewartGilray
    Jun 6, 2011
    11
    Um... no I'm running ...
    3CXPhoneSystem10.exe
    Is that not the correct file?
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, when you are downloading 3cxphonesystem from this link - http://www.3cx.com/ip-pbx/downloadlinks.html are you saving the file so when it downloads completely you select run?
    Or when pressing the link - you are pressing immediately run?
  5. StewartGilray
    Jun 6, 2011
    11
    Problem solved...
    Damn windows update issue.
  6. StewartGilray
    Jun 6, 2011
    11
    Hey Michael, I've got 30 years experience in computers, so am aware of the dos' n donts' but thanks ;)
  7. Roshen
    Jan 16, 2009
    35
    Mind posting how you fixed it? i have the same issue, installing onto windows 2008 SBS
    -Roshen
  8. Roshen
    Jan 16, 2009
    35
    nevermind, the installation succeeded after a server reboot
    -Roshen
