Solved Failover on Enterprise
Discussion in '3CX Phone System - General' started by neville, Oct 9, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    230
    43
    I have been working with failover today and had a question about IP addressing. Both servers are on the cloud.
    I assume that the network on each server needs to be set to dynamic so the address changes in 3CX DNS. At least, this is the only way to get the address changed at failover that I have found. Is this correct or am I missing something?
    All else is working great.
  2. Archie Frederic
    Jan 31, 2017
    72
    I think you could assign different static addresses on both servers. No need to go through dynamic.
  3. StefanW
    Jun 2, 2009
    1,229
    95
    the IP address setup should be static and configured accordingly in each PBX used.
    The Failover System will register at startup the new IP address on your FQDN which is used for external devices to connect to (STUN, SBC, 3CXPHone, Presence)...
    Depending on your license Type the TTL is different to speed up this process. Ent lics have an ttl of 5 minute to speed up the process but DNS propagation can be overridden by any intermediate DNS cache server.
  4. neville
    neville New Member
    Apr 23, 2012
    230
    43
    I need to test this during client demos. How to I fail back to the primary server if I want?
  5. neville
    neville New Member
    Apr 23, 2012
    230
    43
    I shut down my active server. The passive server started all the services. However, the fqdn still points to the active server IP after 15+ minutes. I went to a public dns server to make sure it was not a dns cache issue, but the active ip still shows up.
  6. Archie Frederic
    Jan 31, 2017
    72
    As far as I know, it would take some time for the IP to take effect.
  7. StefanW
    Jun 2, 2009
    1,229
    95
    Depending on your license Type the TTL is different to speed up this process. Ent lics have an ttl of 5 minute to speed up the process but DNS propagation can be overridden by any intermediate DNS cache server. If you use your own custom FQDN, then you need to ensure that the IP is changed!
  8. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,752
    273
    @StefanW Care to post what the TTL is for each version? Seems like important information to know for those folks trying to decide what version to purchase.
  9. neville
    neville New Member
    Apr 23, 2012
    230
    43
    This is working fine. It takes about 2-3 minutes to failover and get back up. I use google DNS so the TTL is very short.
  10. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    Neville:
    Are these windows machines or Linux machines? I was curious if both linux, what scripts you used to failover the PBXes.
    --Tracy
  11. neville
    neville New Member
    Apr 23, 2012
    230
    43
    These are Linux hosted in the cloud with 3cx.us fqdn. They failover automatically as we are using the Enterprise 3CX license.
  12. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    Neville:
    Looking at the scripts, the primary script shuts down the box or shuts down the services and then turns on the failover server or are the scripts left out? Just curious
    --Tracy
  13. neville
    neville New Member
    Apr 23, 2012
    230
    43
    We do not use any scripts.
  14. StefanW
    Jun 2, 2009
    1,229
    95
    All Keys use an TTL of 6h
    ENT Keys of 5 minutes
  15. cobaltit
    Mar 22, 2012
    1,752
    273
    Great, thanks for the info Stefan!
  16. StefanW
    Jun 2, 2009
    1,229
    95
    welcome
