Failover sync
Discussion in 'Ideas' started by engineering2, Mar 24, 2017.
  1. engineering2
    Apr 4, 2016
    5
    When 3CX server works on failover mode, it has to restore the whole backup file in the scheduled time, it is very good when the two servers are within the same physical network,
    But when the Disaster site and the main site connected through VPN for example, restoring the full backup is not a good idea, specially if the backup contains the recordings of a call center agents,
    So why not doing the restore process to restore the difference only between the current configuration of the passive server and the backup file?
    #1 engineering2, Mar 24, 2017
