Failure to Transfer calls on any phones.
Discussion in '3CX Phone System - General' started by smallcocomputing, Apr 20, 2016.
  1. smallcocomputing
    Apr 20, 2016
    Our office today just stopped transferring any phone calls from any of our phones throughout the office.
    Yearlink t27p
    Sip Provider Flowroute
    An outside call will come in, transferred to an extension, the new extension will pick up and neither end can hear each other. I believe the 487 canceled/invite is the culprit but I need some guidance on fixing the issue. It looks like the SIP provider is refusing the connection.
    Nathan
    20-Apr-2016 11:45:26.468 Leg L:526.1[Line:10000<<+16362323027] is terminated: Cause: BYE from PBX
    20-Apr-2016 11:45:26.468 [CM503008]: Call(C:526): Call is terminated
    20-Apr-2016 11:45:26.453 Leg L:526.7[Extn] is terminated: Cause: BYE from 10.0.0.43:5060
    20-Apr-2016 11:45:22.797 Leg L:526.3[Extn] is terminated: Cause: BYE from 10.0.0.55:5060
    20-Apr-2016 11:45:22.688 [CM503007]: Call(C:526): Extn:103 has joined, contact <sip:103@10.0.0.43:5060>
    20-Apr-2016 11:45:22.672 L:526.7[Extn] has joined to L:526.1[Line:10000<<+16362323027]
    20-Apr-2016 11:45:22.672 NAT/ALG check:L:526.7[Extn] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    20-Apr-2016 11:45:19.178 Currently active calls - 1: [526]
    20-Apr-2016 11:45:16.318 [CM503025]: Call(C:526): Calling T:Extn:103@[Dev:sip:103@10.0.0.43:5060;line=c9924ece9c3373a] for L:526.1[Line:10000<<+16362323027]
    20-Apr-2016 11:45:16.271 [CM503027]: Call(C:526): From: Line:10000<<+16362323027 ("Main DID - 6362254545:REITER NATHAN " <sip:+16362323027@10.0.0.25:5060>) to T:Extn:103@[Dev:sip:103@10.0.0.43:5060;line=c9924ece9c3373a]
    20-Apr-2016 11:45:16.271 [CM503004]: Call(C:526): Route 1: from L:526.1[Line:10000<<+16362323027] to T:Extn:103@[Dev:sip:103@10.0.0.43:5060;line=c9924ece9c3373a]
    20-Apr-2016 11:45:16.256 [CM505003]: Provider:[FLowRoute] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:85694727@47.50.165.26:5060]
    20-Apr-2016 11:45:08.904 NAT/ALG check:L:526.3[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    20-Apr-2016 11:45:04.546 Leg L:526.4[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 10.0.0.7:5060
    20-Apr-2016 11:45:04.546 [CM503003]: Call(C:526): Call to <sip:104@10.0.0.25:5060> has failed; Cause: 487 Request Terminated/INVITE from 10.0.0.7:5060
    20-Apr-2016 11:45:04.531 Leg L:526.2[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    20-Apr-2016 11:45:04.531 [CM503003]: Call(C:526): Call to <sip:101@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.48:5060
    20-Apr-2016 11:45:04.531 Leg L:526.5[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.45:5060
    20-Apr-2016 11:45:04.531 [CM503003]: Call(C:526): Call to <sip:105@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.45:5060
    20-Apr-2016 11:45:04.515 Leg L:526.6[Extn] is terminated: Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    20-Apr-2016 11:45:04.515 [CM503003]: Call(C:526): Call to <sip:103@10.0.0.25:5060> has failed; Cause: 487 Request Cancelled/INVITE from 10.0.0.43:5060
    20-Apr-2016 11:45:04.406 [CM503007]: Call(C:526): Extn:102 has joined, contact <sip:102@10.0.0.55:5060>
    20-Apr-2016 11:45:04.406 [CM503007]: Call(C:526): Line:10000<<+16362323027 has joined, contact <sip:85694727@sip.flowroute.com:5060>
    20-Apr-2016 11:45:04.406 L:526.3[Extn] has joined to L:526.1[Line:10000<<+16362323027]
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    You apparently have a ring group consisting of a number of extensions
    There was an initial call that came into the ring group and was answered by 102. When answered the system had to send the a cancel to the other extension so they would know that the call had been answered and there was no reason to continue the ring. It then looks like ext 102 transferred the call to 103. 103 joined the call, but then some 4 second or so later, ended the call. I can't really say why the call ended.
    You might check the license and see if still fully activated
    Check the firmware of the phone to see if an update is required for the version of 3CX in use.
    Check the settings for Flowroute. Under advanced trunk capabilitues only PBX provides audio should be checked
    Restart the system if all else fails.
  3. smallcocomputing
    Apr 20, 2016
    Ineblett,
    Sorry for getting back to you so slowly. I did a reboot of the system and that took care of the weird no forwarding issue.
    Thanks for your reply.
    Nathan
