Fake calls from ext 100
Discussion in '3CX Phone System - General' started by Buddyl, Sep 16, 2013.
  1. Buddyl
    Nov 8, 2012
    12
    I have the 3cx phone system, the Free version. 10.0.24018.2322
    I have an extension at home that connects through the internet (Not using Tunneling) It is a grandsteam phone GXP2120
    I get calls at sporadic times to this extension claiming they are coming from Ext 100.
    We do not have an extension 100. One time I seen a name associated with xt 100 as Sid (maybe sip) Vicious.
    When the call comes in and I answer there is no one there. If I let it ring all of the lines will light up. I usually have to unplug it and reboot.
    Any ideas???
    Thank you
    Buddy
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Check the call logs to see if that call is coming from an outside IP that isnt yours!
  3. leejor
    11,277
    360
    You might want to change the port of your device to something other than the (usual) default of 5060. If someone sends a direct SIP call to your IP (and that port number), and guesses your extension number, you will get the call.
    If it happens on a predictable basis, you might want to employ Wireshark to give you some more information about the origination.
