Solved "fake" extension not working
Discussion in '3CX Phone System - General' started by JerN, Aug 2, 2017.
  1. JerN
    Mar 24, 2017
    14
    I have created an extension with a voicemail for after hours calls. When a user selects this through the IVR it is supposed to transfer directly to the voicemail which emails the message to the person on call. There is no phone provisioned to this extension as it is used for voicemail only.
    Because there is no phone provisioned in the extensions page the status is in red. When I call the extension rather than being forwarded to the voicemail I'm returned with a "Forbidden" message on my phone and the call disconnects. How do I enable this extension without assigning a phone to it?
    Thanks.
  2. JerN
    Mar 24, 2017
    14
    I figured it out. I had been testing MS Exchange UTM but decided not to use it. The VM was still set to use Exchange Server so it was looking for a non existent mailbox. Once the option was turned off it worked as expected.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,455
    541
    Glad the issue is resolved and thank you for sharing your solution
