Fanvil C600 How to Force the initial 3CX login prompt
Discussion in '3CX Phone System - General' started by FGCUHank, Oct 31, 2017.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Found a messy one. I flubbed the users extension on the 3CX prompt during initial provisioning.
    How do you get that prompt to come back? I had to factory reset and re-install the 3CX firmware a number of times and eventually it came up.
    hg
  2. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Just a ping on this one also, thanks
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @FGCUHank
    Can you tell me what firmware your C600 is running so i can try to replicate?
    Thank you
  4. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Looks like I have 2 hardware versions and as of this am both are saying not supported
    C600 13.306.238.28.B
    C600 13.366.320.41.2
    Also have a X3S that keeps loosing its password on reboot running 2.0.4.3496
    Suspecting I missed a recent firmware release?
