Fanvil C600 will not accept firmware 13.366.320.41.2
Discussion in '3CX Phone System - General' started by FGCUHank, Oct 31, 2017.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    I have two C600's purchased about 8 weeks apart.
    One will only run 3CX firmware 13.305.238.28.B. It rejects the firmware 13.366.320.41.2 as not compatible.
    The other C600 installed 13.366.320.41.2 without issue.
    Before each firmware install and install attempt, I did reset the phone to factory configuration and also installed the latest Fanvil firmware from their website. 13.247.150.5.B-2017-01-10-u
    Both phones are working fine but the extension with 13.306.238.28.B reports a not supported firmware version on the phones page on the admin console.
    Any suggestions would be greatly appreciated.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @FGCUHank
    Please note that there are 2 hardware versions of this phone. The firmware we supply is for V2. Check which hardware you have and follow the instructions in the guide below. It mentions the firmware needed for hardware version 1 under the limitations section.
    https://www.3cx.com/sip-phones/fanvil-c-series/
