Fanvil DHCP option for VLAN
Discussion in '3CX Phone System - General' started by jholcombe, Oct 27, 2015.
  1. jholcombe
    Jul 9, 2014
    79
    Does anybody know if there is a DHCP option on Fanvil phones to assign it to a particular VLAN? I can't find anything in their documentation about this. There are VLAN settings, there are DHCP options, just no DHCP options for VLAN settings... Wondering if I'm just not seeing it.
    Thank you!,
    --John
  2. jholcombe
    Jul 9, 2014
    79
    Received this reply from Fanvil. I haven't had a chance to try it yet:
    Subject: 答复: Set VLAN via DHCP
    Hi, John
    After check the settings about Yealink.
    Our phone can do it, but we use DHCP option 43(it same as 132)
    But can you show me your method of application? If you set VLAN via DHCP option, it need your DHCP server supports.
    Such as:
    1. Now phone turn off VLAN, phone get DHCP IP, and DHCP server tell me turn on VLAN, and ID:20
    2. Now phone is enable VLAN, and have a ID, if it’s not DHCP server in the ID:20, phone will lost registered etc.
    Our phone support LLDP, you can test it.
    Best Regards,
    Mask Ma
    FAE engineer
    Fanvil Technology Co., LTD.
  3. PhatPanda
    Aug 26, 2015
    58
    Any updates on this? About to try out using option 43 myself.
