Fanvil i20s supported?
Discussion in '3CX Phone System - General' started by Oscar Gimenez, Jun 1, 2017.
Tags:
  1. Oscar Gimenez
    Jun 1, 2017
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Plug it in and see if 3cx detects it.
    I have some Fanvil X4G and although not specifically stated under supported phones, it shows up as an X4.
    It is possible the i20s just uses the i20 template without issue.
  3. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Oscar Gimenez,
    The specific model is not tested from us. You can contact Fanvil and ask for a template.
