Fanvil Timeout Problem
Discussion in '3CX Phone System - General' started by narkumas, Apr 6, 2017.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Argh! Since the last firmware update on Fanvil X3s and X4 and the use of the new templates, I have a very big problem. Almost daily some phones run in timeouts and display "SIP registration failed".
    I have to reboot them daily. I cannot see the reason.
    Can someone help? Any ideas?
    Fanvil X4 Firmware: 2.0.3.2992
    3CX 15.0.0 (most actual)
    //Marius
    Daniele Rebellato likes this.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @narkumas
    Please note that currently there is an issue with Fanvil phones causing the behaviour you are experiencing. When the phones lose connection to the server for any reason then they do not re-register .
    We have reported this to fanvil and they have already fixed it. It will be available in a upcoming update.
  3. insight3
    Oct 8, 2013
    Is this a 3CX update or a firmware update we need to look out for? I have just installed 60+ Fanvil's onto one site and this is a major issue to us. On the 3CX Provisioning page for the Fanvil phones it still says
    Known Limitations
    • Currently no known limitations.
    Surely this needs to be updated to reflect this problem.
    Taff3333 likes this.
  4. Daniele Rebellato
    Apr 13, 2017
    Hi, I have the same problem TIME OUT than
    narkumas
    In my farm we have 40 fanvil X3s and X4 (Firmware 2.0.3.2992) and every day we have to reboot 10-15 telephones to return ON LINE
  5. Stéphane DAGUET
    Apr 13, 2017
    Dear All,
    Experiencing the same issue. Any information on the update release date ?
    Regards
  6. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    Hum, Hum...
    when does 3CX intend to publish the new firmware to fix that major bug?
  7. YiannisH_3CX
    May 10, 2016
    7,341
    535
    I do not have a date for you as the firmware is still being tested by our R&D department.
  8. insight3
    Oct 8, 2013
    Is there an update on this yet as I am desperate not to hack off my customer to the point of removing 3CX?
  9. dan_tx
    dan_tx New Member
    Nov 3, 2016
    105
    29
  10. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    Is there a way to reach Fanvil support? Emails get rejected.
  11. dan_tx
    dan_tx New Member
    Nov 3, 2016
    105
    29
    I emailed them last week without issue, got a response within 24 hours. It was about an x6.
  12. gavpop
    Jul 24, 2012
    29
    I am also suffering this problem.
    Causing me huge headaches and making my brand new 3CX phone system look like a pile of crap.
    FIX ASAP.
  13. Taff3333
    Jan 18, 2017
    21
    6
