Fanvil x3s Background Image
Discussion in '3CX Phone System - General' started by gavpop, Mar 24, 2017.
  1. gavpop
    Jul 24, 2012
    29
    Does anyone know how to change the background image on Fanvil phones?
    All the marketing literature clearly shows it displaying an image, but I have no idea how to set it
    AH2 likes this.
  2. maiten
    Apr 22, 2015
    I'm interested in this as well. It seems it's possible as the original firmware had one image and after updated to a new one it has a 3CX logo while booting and no image as background.
  3. AGidi
    Jun 30, 2017
    39
    I had my custom imagen and was replaced with 3CX, where is this image located so we can upload ours again?
  4. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Any one ? Im looking for this as well.
    Thanks.
    AH
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    You could try creating a custom template based on the article here: https://www.3cx.com/docs/custom-ip-phone-templates/
    3CX does not provide support for custom templates, but you could find the template line change it to another link where your file is located so that the phone can load it. The only piece of advice I can give is that phones can be a bit 'picky' in the image file format, so make sure you check the manufacturer documentation about the format, color depth, dimensions, etc.
    AH2 likes this.
