Fanvil X5 setup Help
Discussion in '3CX Phone System - General' started by thames, Nov 12, 2016.
  1. thames
    thames New Member
    Apr 4, 2011
    102
    Hi Folks
    Have a Fanvil X5 set up using STUN as a remote extension and trying to get the BLFs working. The attachment is what my initial setup looks like. The buttons actually work but I cannot get the BLFs to light up.
    Any help would be greatly appreciated.
    Cheers
    Chris
  2. mortenjorge
    Apr 1, 2015
    58
    11
    Hi Thames,
    Do you use the free PBX editions?
    You can still use BLF, but they will not "light" up.
    Please make sure, that the license is still activated if you use standard/Pro licens.
  3. thames
    thames New Member
    Apr 4, 2011
    102
    Hi mortenjorge
    Yes - I have 8 SC Pro edition which is licensed and activated correctly. I have now resolved this issue (see attachment). The phone setup was not correct but it is sorted now by Auto Provision and all working great.
    Thanks for your reply.
    Cheers
    Chris
