fax and stun
Discussion in '3CX Phone System - General' started by regfixit, Mar 7, 2008.
  1. regfixit
    Mar 7, 2008
    35
    I've just installed the 3CX phone system and must say I am very impressed so far, especially for free software.
    However, in the server log I am getting some messages that I am not sure of the cause:
    Every 10 minutes there is a message about a fax user, but as far as I know I didn't set up one:
    09:58:08.677 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:88@3CXPhoneSystem with contact sip:88@192.168.0.12:5100;user=phone
    09:58:08.162 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
    09:48:08.162 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:88@3CXPhoneSystem with contact sip:88@192.168.0.12:5100;user=phone
    09:48:07.208 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
    Anybody know where this fax user is coming from ?
    Also, there is a message about not having a STUN server set up
    09:26:49.193 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    In fact I have a static IP and so don't need a STUN server - is there a way to enter the static IP and turn off the STUN server section ?
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    This is normal behavior. See technical manual. This is virtual fax extension.
  3. regfixit
    Mar 7, 2008
    35
    Thanks for quick reply about the fax. So I can see this is built in, but why does it unregister and register every 10 minutes. Is there a way to stop this or to stop it cluttering up the log ?
  4. igor.snezhko
    Jan 7, 2008
    668
    7
    Just stop and configure to manual start the 3CX FAX service in Windows
    These log messages are very helpful to ensure that FAX service in 3CX really works and can receive faxes. So that is good idea to "heartbeat" fax presence.
  5. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    It is not really a virtual fax. You really need a hardware gateway from Patton to let it work. As far as I know there' s no one who has the fax thing running only virtually. Read the manual or this Forum about the subject
  6. igor.snezhko
    Jan 7, 2008
    668
    7
    Of course, you need ANY gateway with T.38 support. Not only Patton. I use cheap Dlink 4 FXO gateway. It costs about 250$
  7. regfixit
    Mar 7, 2008
    35
    Can I use the linksys spa3102 for fax as that is what I am using for my fxo gateway.
    Also, if a receive a call how do I direct it to the fax extension - I tried dialling 88 from one of my IP phones but it didnt work - it looks like it tried to dial out my voip gateway with number 88 instead:
    09:48:07.583 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:88@3CXPhoneSystem with contact sip:88@192.168.0.12:5100;user=phone
    09:48:07.224 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
    09:46:16.865 Call::Terminate [CM503008]: Call(41): Call is terminated
    09:46:16.802 Call::RouteFailed [CM503014]: Call(41): Attempt to reach "88"[sip:88@192.168.0.12:5060] failed. Reason: Not Found
    09:46:16.802 CallLeg::eek:nFailure [CM503003]: Call(41): Call to sip:88@voiptalk.org:5060 has failed; Cause: 404 Not Found; warning: Noisy feedback tells: pid=32177 req_src_ip=217.14.138.177 req_src_port=5065 in_uri=sip:88@voiptalk.org:5060 out_uri=sip:88@voiptalk.org:5060 via_cnt==1; from IP:77.240.48.94:5060
    09:46:16.537 CallLeg::eek:nFailure [CM503003]: Call(41): Call to sip:88@voiptalk.org:5060 has failed; Cause: 404 Not Found; warning: Noisy feedback tells: pid=32176 req_src_ip=217.14.138.177 req_src_port=5065 in_uri=sip:88@voiptalk.org:5060 out_uri=sip:88@voiptalk.org:5060 via_cnt==1; from IP:77.240.48.94:5060
    09:46:16.162 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(41): Calling: VoIPline:10001@[Dev:sip:844114078@voiptalk.org:5060, Dev:sip:844114078@voiptalk.org:5060]
    09:46:15.880 CallCtrl::eek:nIncomingCall [CM503001]: Call(41): Incoming call from Ext.10 to "88"[sip:88@192.168.0.12:5060]
    09:38:07.208 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:88@3CXPhoneSystem with contact sip:88@192.168.0.12:5100;user=phone
  8. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    I believe that the Fax doesn't work in the free version
    Stephen
  9. igor.snezhko
    Jan 7, 2008
    668
    7
    FAX is not work in free version of course.
