Fax and Voice use same DID
Discussion in '3CX Phone System - General' started by soli, Feb 14, 2016.
  1. soli
    Feb 14, 2016
    8
    how can i use Fax and Voice useing the same DID?
    is it possible for 3cx system to know if the call is from fax or voice?
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    No it can be configured for voice or fax routing there is no auto detection.
