Fax Calls On 3cx
Discussion in '3CX Phone System - General' started by sata, Aug 21, 2007.
  1. sata
    Jul 16, 2007
    22
    i am looking for some help on steting up a fax on my 3cx can this be done and if so what is the best cores of action to take
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    If you want to set up a FAX ( T.38 ) machine to 3CX via FXS port. The current version of 3CX (v3.1.2434.0) still cannot be supported.
