Fax Client out the Office
Discussion in '3CX Phone System - General' started by Egor, May 4, 2017.
  1. Egor
    May 4, 2017
    Can I turn off this block?
    "Fax.888: blocked request from non-local source <out_the_office>:5060"
    Best Regards,
    Egor
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Egor,
    Where and when do you see this message? Do you have a remote fax device?
  3. Egor
    May 4, 2017
    It's message from Log of dashboard.
    I used VentaFax client. Local ip is works but remote doesn't work.
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
    Hello @Egor,
    By default the fax server works only locally. You cannot use it remotely, that is why you get the error.
  5. Egor
    May 4, 2017
    Can I change these settings?
  6. Panayiotis_3CX
    Apr 26, 2017
    165
    7
    @Egor,
    Unfortunately there aren't any settings to solve this. The specific service works only locally.
  7. Egor
    May 4, 2017
    Ok! Thank You!
