Fax device - busy tone
Discussion in '3CX Phone System - General' started by muaddib32, Feb 21, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    Finally got the fax working (fax device not the fax server) and discovered that if the fax line is busy an external fax machine gets a message that the user at xxxxx is busy and that their voicemail is full.
    This is not very useful. Is there a way to change this? It would be better if the external fax machine just got a busy signal.
