Fax Extension not registered (Ver 8)
Discussion in '3CX Phone System - General' started by integrax, Apr 28, 2011.
  1. integrax
    Dec 9, 2008
    19
    We are using Ver 8 (not free) with nexVortex as VoIP provider and one dedicated DID number for fax extension (888).
    When we call the DID number from outside, the system picks the call but after few seconds it gets disconnected, with failed error because not registered, as you can see on log lines:
    10:30:20.812 [CM503008]: Call(426): Call is terminated
    10:30:20.781 [CM503020]: Normal call termination. Reason: Not available
    10:30:20.781 [CM503016]: Call(426): Attempt to reach <sip:888@192.168.XX.10:5060;user=fax> failed. Reason: Not Registered
    10:30:20.781 [CM503017]: Call(426): Target is not registered:
    10:30:20.781 [CM503010]: Making route(s) to <sip:888@192.168.XX.10:5060;user=fax>
    10:30:20.765 [CM505003]: Provider:[888VoIP] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:MainFax@71.152.XXX.XXX:5060]
    10:30:20.765 [CM503001]: Call(426): Incoming call from 1XXX6243903@(Ln.10001@888VoIP) to <sip:888@192.168.XX.10:5060;user=fax>
    10:30:20.687 [CM503012]: Inbound office hours rule (MainFax) for 10001 forwards to Fax:888
    10:28:41.671 [CM504004]: Registration succeeded for: 10001@888VoIP
    10:28:41.421 [CM504003]: Sent registration request for 10001@888VoIP
    10:28:39.875 [CM504004]: Registration succeeded for: 10001@888VoIP
    10:28:39.609 [CM504003]: Sent registration request for 10001@888VoIP
    10:28:11.375 [CM504008]: Fax Service: registered as sip:888@192.168.XX.10:5060 with contact sip:888@192.168.XX.10:5100;user=phone
    Any help will be appreciated
    Thank you
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Have you tryed restarting the Fax Service within 3CX?
  3. integrax
    Dec 9, 2008
    19
    Thank you for your promt response and........
    Yes, we restarted Fax server first and also restart all, but even after that log file still shows the unregistered error.
    Extension 888 shows green light and registered idle on system extensions status panel, apparently it has been registered ok.
    Any ideas?.........
  4. davidbenwell
    Apr 27, 2010
    704
    Do you have a fax connected to a phone line to do a test as calling from
    A phone will result in a disconnect
  5. integrax
    Dec 9, 2008
    19
    Lets see if I do understand what you are asking me.
    The Fax machine (hardware) is located at next door office and connected to a regular stand alone phone line.
    That machine is working perfectly to send and receive faxes and we are using it to send a fax to one of our nexVortex DID numbers, the one with send fax to email extension configuration.
    BTW, we installed RelayFax and assigned it a diffrent extension number and when we call that DID, the call get connected and we se some activity on RF console but after few seconds, RF received panel get an err or non-fax call error.
    Thank you
