Fax extension unregisters
Discussion in '3CX Phone System - General' started by redmondsau, May 24, 2014.
  1. redmondsau
    Oct 24, 2012
    6
    Hoping someone can assist.
    I am running latest version of 3CX and love it. However some inderterminate time ago the fax stopped working. Not sure if it was related to an update or not.
    However on investigation it appears the fax is periodically unregistering itself and fails to reregister. If I restart the Fax service the Fax will register. It stays registered for an apparently random amount of time.
    See the Activity Log Below.
    24-May-2014 21:25:12.610 [CM504008]: Fax Service: Fax.888 registered as sip:888@127.0.0.1:5060 with contact sip:888@127.0.0.1:5100;user=phone
    24-May-2014 21:06:38.075 [CM504010]: Fax Service: Fax.888 unregistered contact sip:888:5100;user=phone
    24-May-2014 20:46:10.592 [CM504008]: Fax Service: Fax.888 registered as sip:888@127.0.0.1:5060 with contact sip:888@127.0.0.1:5100;user=phone
    24-May-2014 20:45:07.136 [CM504010]: Fax Service: Fax.888 unregistered contact sip:
    24-May-2014 20:44:00.235 Configuration of Fax.888 has been updated from database
    24-May-2014 20:30:06.769 [CM504008]: Fax Service: Fax.888 registered as sip:888@127.0.0.1:5060 with contact sip:888@127.0.0.1:5100;user=phone
    24-May-2014 20:30:01.524 Configuration of Fax.888 has been updated from database
    24-May-2014 20:24:34.792 Configuration of Fax.888 has been updated from database
    24-May-2014 20:24:29.822 Configuration of Fax.888 has been updated from database
    24-May-2014 20:24:19.478 Configuration of Fax.888 has been updated from database
    24-May-2014 20:21:06.115 [CM504010]: Fax Service: Fax.888 unregistered contact sip:888:5100;user=phone
    24-May-2014 20:10:47.787 [CM504008]: Fax Service: Fax.888 registered as sip:888@127.0.0.1:5060 with contact sip:888@127.0.0.1:5100;user=phone
    Current status is I created a new Fax extension 887. This extension has failed to register but 888 has registered. Waiting to see for how long but it has been about 10 mins so far.
    Thanks for any assistance anyone can offer
    Regards
    redmondsau
  2. redmondsau
    Oct 24, 2012
    6
    Update:
    The 888 Fax Extension unregistered again. So both 888 & 887 are unregistered. It appears to be staying registered for an additional 5 mins each time.
    24-May-2014 22:05:40.914 [CM504010]: Fax Service: Fax.888 unregistered contact sip:888:5100;user=phone
    24-May-2014 20:46:10.592 [CM504008]: Fax Service: Fax.888 registered as sip:888@127.0.0.1:5060 with contact sip:888@127.0.0.1:5100;user=phone.
    Redmondsau
  3. lpendas
    Jul 18, 2014
    6
    I am having the same problem, is this a known issue?
    Has anybody reached a solution/workarround?
    regards
  4. narvis
    Feb 1, 2010
    Same problem here.
    I have set up a job to reset the FAX service periodicly but sometimes even that doesn't help.
    Regards,
    Bojan
  5. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Kindly open a support ticket on our support portal so that we can investigate this further with your configuration.
  6. scrollz
    Jul 24, 2015
    11
    also my fax is randomly unregistered
