Fax Extensions - Outbound Rules - Extension Group Ignored
Discussion in '3CX Phone System - General' started by paul1, Oct 22, 2011.
  1. paul1
    Jan 14, 2010
    80
    I have created an outbound rule to block a specific extension group from being able to make non-emergency outbound calls. Even though my fax extensions are not members of this group the rule still catches the fax calls.
    I have duplicated the problem on two systems. Anybody else experiencing the same issue?
    Seems like a bug in the 3cx fax dialing logic...
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Re: Fax Extensions - Outbound Rules - Extension Group Ignore
    Seems only a rule listing fax extensions has effect (first in order to match).
    Another problem with fax extensions is you can not specify outgoing caller-id like other normal extensions.
    Regards
