Fax gateway disconnects incomming fax
Discussion in '3CX Phone System - General' started by Powermage, Mar 31, 2008.
  1. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    When i try to test an incomming fax to our new 3cx voip server i have the problem that the line will disconnect.
    The incomming line is working fine, but when i set the "wich calls are faxes" option to 'All calls' any caller or incomming fax will be disconnected, in the logfile of the server i can see the following:
    15:41:58.148 MediaServerReporting::RTPReceiver [MS105000] C:310.2: No RTP packets were received:remoteAddr=192.168.17.40:10008,extAddr=0.0.0.0:0,localAddr=192.168.17.40:7022
    15:41:58.148 Call::Terminate [CM503008]: Call(310): Call is terminated
    15:41:58.101 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for DID:Faxen forwards to Fax:88
    15:41:58.101 LineCfg::getInboundTarget [CM503009]: DID rule (Faxen) is applied to call from sip:number@3cx.domain.local:5060 to XXXXXXXXXXXX
    15:41:58.086 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for DID:Faxen forwards to Fax:88
    15:41:58.086 LineCfg::getInboundTarget [CM503009]: DID rule (Faxen) is applied to call from sip:number@3cx.domain.local:5060 to XXXXXXXXXXXX
    The services on the server (server 2008) are running fine, the version is the latest version (if i can believe the auto update function)
    what next to do?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    Are you using a Patton gateway? I see you are running on Windows 2008 server - we have not tested that platform yet btw.
  3. Powermage
    Mar 19, 2008
    103
    No, i am not using a gateway, i use a SIP line from a dutch provider (solcon) we also use them for our normal in and outbound call's and accept for DTMF tones (dialing menu's of the party's we are calling are not working but i am busy with that right now) everything seems to work fine. i will try to make an backup and restore on an windows XP Pro machine in the end of the day.
  4. Powermage
    Mar 19, 2008
    103
    Just made an backup of the 2008 server and restored it on an windows XP-pro installation but i still have the same error like on the 2008 server.
    [edit] Also when i use an 'internal' voip telephone to dial '88' (default fax) i get the same error in the logfile, i think at least i need to get an FAX tone?
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    Download a tool called wireshark, and you should be able to trace whats happening.
    You may find its your provider which is causing the problem - t.38 is still very unstable over the internet.
  6. Powermage
    Mar 19, 2008
    103
    I am alrady tracing with wireshark but even when i call with an cell phone to the fax only number the line gets disconnected without an fax tone, even when i call with an internal voip phone to the fax extension (88 default) i get the error so i think it is somthing different. also as far as i can see in wireshark i cant find anything strange.
  7. SWB
    SWB New Member
    Mar 26, 2008
    136
    Receiving the exact same problem here. Have a supported Grandstream gateway (GXW4104) setup and configured via 3CX instructions. Have never been able to get fax to email to work. My log is identical to yours, and also when I manually call get disconnected promptly.
  8. adinets
    Jun 24, 2008
    7
    Same here. Using XeLoQ, 3cx approved sip provider.
  9. Anonymous
    Anonymous Guest
    Hey there,
    Just wanted to let you know that 3CX currently does not support fax over VoIP.
    Thanks,
