Fax / Music issue.
Discussion in '3CX Phone System - General' started by sssputnik, Jun 18, 2010.
  1. sssputnik
    Apr 21, 2010
    25
    Latest public release version of 3CX.
    VoIP provider uses Broadsoft/Broadworks.
    We have issue where callers don't get any music on hold during attended transfers.
    I can fix this by setting VoIP Provider to PBX Supplies Audio.
    However this breaks inbound faxing.
    (Fax answers then hangs up after about 15 seconds).
    Anyone got any ideas? I can post logs but unsure if they will show much. Hoping this is some sort of known issue.
    I am hoping version 9 will fix it.
  2. carolinainnovative
    May 4, 2009
    369
    6
    From my experience, voip providers work better with PBX Delivers Audio turned on.
    My recommendation would be see if your voip provider can issue you a second set of credentials and setup a separate voip provider entry in 3cx specifically for the inbound/outbound faxing. I've had good success with that.
