FAX not working when call comes in as Anonymous
Discussion in '3CX Phone System - General' started by coreybrett, May 21, 2010.
  1. coreybrett
    Apr 12, 2010
    72
    I have Callcentric as a provider, and a DID setup for fax reception.
    It works fine if the incoming call is not anonymous, but if it is, they don't get the fax handshake.
    I've verified this with my iPhone.
    If I call my fax number I get a handshake.
    If I block my caller ID on my iPhone and call my fax number, it picks up but I just get silence.
  2. coreybrett
    Apr 12, 2010
    72
  3. leejor
    11,283
    360
    You might want to post a couple of 3CX (Verbose) logs. One of the call completing successfully and one anonymous call failing.
  4. coreybrett
    Apr 12, 2010
    72
    Code:
    22:38:11.267  [CM503008]: Call(2): Call is terminated
    22:38:10.813  Remote SDP is set for legC:2.2
    22:38:09.545  Session 153 of leg C:2.1 is confirmed
    22:38:09.483  [CM503007]: Call(2): Device joined: sip:888@192.168.76.19:5100;user=phone
    22:38:09.467  [CM503007]: Call(2): Device joined: sip:17772023385@callcentric.com:5060
    22:38:09.436  [MS210007] C:2.1:Answer provided. Connection(by pass mode): 192.168.76.19:10002(10003)
    22:38:09.404  [MS210001] C:2.2:Answer received. RTP connection[unsecure]: 192.168.76.19:10002(10003)
    22:38:09.389  Remote SDP is set for legC:2.2
    22:38:09.373  [CM503002]: Call(2): Alerting sip:888@192.168.76.19:5100;user=phone
    22:38:08.982  [CM503025]: Call(2): Calling @[Dev:sip:888@192.168.76.19:5100;user=phone]
    22:38:08.966  [MS210006] C:2.2:Offer provided. Connection(by pass mode): 204.11.192.39:49358(49359)
    22:38:08.872  [CM503004]: Call(2): Route 1: @[Dev:sip:888@192.168.76.19:5100;user=phone]
    22:38:08.872  [CM503010]: Making route(s) to <sip:221@192.168.76.19:5060;user=fax>
    22:38:08.856  [MS210000] C:2.1:Offer received. RTP connection: 204.11.192.39:49358(49359)
    22:38:08.825  Remote SDP is set for legC:2.1
    22:38:08.809  [CM505003]: Provider:[callcentric] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:17772023385@74.92.26.202:5060]
    22:38:08.731  [CM503001]: Call(2): Incoming call from anonymous@(Ln.10000@callcentric) to <sip:221@192.168.76.19:5060;user=fax>
    22:38:08.622  [CM503012]: Inbound out-of-office hours rule (Corey Boyle's Fax) for 10000 forwards to Fax:221
    22:38:08.622  Looking for inbound target: called=16173998217; caller=anonymous
    22:38:08.528  [CM500002]: Info on incoming INVITE:
      INVITE sip:17772023385@74.92.26.202:5060;rinstance=746f3ca044bd06b0 SIP/2.0
      Via: SIP/2.0/UDP 204.11.192.39:5060;branch=z9hG4bK-cfe7e09b25e61c9e0bcdcdb192eecf45
      Max-Forwards: 15
      Contact: <sip:cf1f1dc699f3c9850a06c2035c47d954@204.11.192.39:5060;transport=udp>
      To: <sip:16173998217@ss.callcentric.com>
      From: "Anonymous"<sip:anonymous@callcentric.com>;tag=3483743900-473295
      Call-ID: 3843654-3483743900-473269@msw1.telengy.net
      CSeq: 1 INVITE
      Supported: timer
      Content-Length: 0
    22:38:06.555  Active calls counted toward license limit: []
    22:37:42.403  [CM503008]: Call(1): Call is terminated
    22:37:38.364  Remote SDP is set for legC:1.1
    22:37:37.879  Remote SDP is set for legC:1.2
    22:37:36.626  Session 147 of leg C:1.1 is confirmed
    22:37:36.517  [CM503007]: Call(1): Device joined: sip:888@192.168.76.19:5100;user=phone
    22:37:36.486  Active calls counted toward license limit: [1]
    22:37:36.486  [CM503007]: Call(1): Device joined: sip:17772023385@callcentric.com:5060
    22:37:36.454  [MS210007] C:1.1:Answer provided. Connection(by pass mode): 192.168.76.19:10002(10003)
    22:37:36.439  [MS210001] C:1.2:Answer received. RTP connection[unsecure]: 192.168.76.19:10002(10003)
    22:37:36.407  Remote SDP is set for legC:1.2
    22:37:36.407  [CM503002]: Call(1): Alerting sip:888@192.168.76.19:5100;user=phone
    22:37:36.220  [CM503025]: Call(1): Calling @[Dev:sip:888@192.168.76.19:5100;user=phone]
    22:37:36.204  [MS210006] C:1.2:Offer provided. Connection(by pass mode): 204.11.192.39:49354(49355)
    22:37:36.141  [CM503004]: Call(1): Route 1: @[Dev:sip:888@192.168.76.19:5100;user=phone]
    22:37:36.141  [CM503010]: Making route(s) to <sip:221@192.168.76.19:5060;user=fax>
    22:37:36.141  [MS210000] C:1.1:Offer received. RTP connection: 204.11.192.39:49354(49355)
    22:37:36.110  Remote SDP is set for legC:1.1
    22:37:36.063  [CM505003]: Provider:[callcentric] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:17772023385@74.92.26.202:5060]
    22:37:35.985  [CM503001]: Call(1): Incoming call from 12073189521@(Ln.10000@callcentric) to <sip:221@192.168.76.19:5060;user=fax>
    22:37:35.813  [CM503012]: Inbound out-of-office hours rule (Corey Boyle's Fax) for 10000 forwards to Fax:221
    22:37:35.578  Looking for inbound target: called=16173998217; caller=12073189521
    22:37:35.484  [CM500002]: Info on incoming INVITE:
      Via: SIP/2.0/UDP 204.11.192.39:5060;branch=z9hG4bK-0a9bc269dde06c464102dd92b406b78a
      Max-Forwards: 15
      Contact: <sip:d914ed7bc49f92fffe0f9f06b092307d@204.11.192.39:5060;transport=udp>
      From: <sip:12073189521@66.193.176.35>;tag=3483743867-432350
      Call-ID: 3843582-3483743867-432319@msw1.telengy.net
      CSeq: 1 INVITE
      Supported: timer
      Content-Length: 0
    22:37:04.428  Active calls counted toward license limit: []
  5. leejor
    11,283
    360
    Interesting that on the working call you get:
    but not on the anonymous calls.
    You also get...
    as opposed to ...
  6. coreybrett
    Apr 12, 2010
    72
