FAX outgoing rule 3CX PBX v.10
Discussion in '3CX Phone System - General' started by Sergiy, Jan 30, 2014.
  1. Sergiy
    Dec 12, 2011
    15
    Hi all!
    Today I became a victim of external bot attack.
    History: I moved two weeks before my 3CX Server to virtual machine with two network interfaces (LAN, WAN). When I loaded settings to the new server I noticed that passwords weren't recovered, so I had generated new passwords and it seemed all OK, but I forgot about FAX extension (8888) which password was blank.
    At this morning my phone provider called to me and said that very intensive international traffic was detected from my account. Fax service had passed over outgoing rules (which allows only specified numbers international outgoing access with prefix "00") and did calls directly. Does the FAX obey on outgoing rules?
    11,073
    323
    Without outbound rules there would be no way that calls would know where to route, so yes, FAX calls will use outbound rules. Place a call from the FAX line, then have a look at the 3CX logs.
    Besides a password change, you could require a prefix several digits in length (that is then stripped in the rules), for international calls. This rule could be made to apply to all extensions, or just the FAX number.
  3. Sergiy
    Dec 12, 2011
    15
    I have just one outgoing rule for international calls and it doesn't contain the FAX number in the allowed numbers list.
    So, FAX number passes outgoing rules for routing only, but stepping over permission part?
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    In your case, the 8888, is this the 3CX fax server that is built-in to the system, or an extension that you created and have setup with an analog fax?
    The reason I ask, is that the built-in fax server is a receive only intended function. I do not know of a way to initiate a call from within 3CX through the server extension. However, I also do not know that it is not possible to connect a phone using that extension number and authentication and thereby be able to connect and make calls. I have never tried it.
    Also, keep in mind that if 8888 is indeed the built-in fax server, then this is not a normal extension but a system extension and therefore not subject to the rules as again, it was designed for inbound only.
  5. leejor
    11,073
    323
    Sorry, the way I have FAX set-up is by using an actual extension (I think it's 889) rather than using the internal FAX server for both incoming an outgoing calls. So, in my case, the fax extension (or any outbound call) will use the appropriate outbound rule.
  6. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Can we look at INVITEs used to call outside using Fax number? So we can better understand the way it was hacked and improve.
  7. Sergiy
    Dec 12, 2011
    15
    Sorry for late answer.
    There is in Windows logs one of such messages:
    Call to 6230037190991221@(Ln.10005@LDK100) has failed. [ V4 192.168.1.130:5060 UDP target domain=unspecified mFlowKey=820 ] replied: 486 Busy Here; from IP:192.168.1.130:5060
    LDK100 - LG NORTEL ipLDK100 connected with 3CX as VOIP-provider (it has added hardware SIP extension module).
    Where I can see an old invite?
  8. archie
    3CX Support
    Aug 18, 2006
    1,299
    You should look in your logs/backup files for the INVITE that has Fax extension number in Contact header and addressed to outside number. If you know the numbers dialled by hackers you can just look up for that number(s).
  9. Sergiy
    Dec 12, 2011
    15
    All numbers that start with 00371 (Latvia) - made by FAX
    IP-addresses from were made calls over FAX are Palestine, Portugal, Germany from. So I think it were infected desktops and I participate as gateway to flood some organization(s).
    3CXDialer (cut):
    Code:
    14.01.30 00:55:40.223|200002| Trc|75|0006|: Del: Call(641) [Connected] DN=10005 IP=(null) EP=62300448009879077
    14.01.30 00:55:43.018|200002| Trc|75|0006|: Ins: Call(642) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.045|200002| Trc|75|0006|: Ins: Call(643) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.068|200002| Trc|75|0006|: Ins: Call(644) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.129|200002| Trc|75|0006|: Ins: Call(645) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.222|200002| Trc|75|0006|: Ins: Call(646) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.313|200002| Trc|75|0006|: Del: Call(646) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.405|200002| Trc|75|0006|: Ins: Call(647) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:43.526|200002| Trc|75|0006|: Del: Call(647) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:55:53.375|200002| Trc|75|0006|: Ins: Call(642) [Ringing] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.393|200002| Trc|75|0006|: Upd: Call(642) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:55:53.410|200002| Trc|75|0006|: Upd: Call(642) [Connected] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.429|200002| Trc|75|0006|: Ins: Call(643) [Ringing] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.445|200002| Trc|75|0006|: Upd: Call(643) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:55:53.461|200002| Trc|75|0006|: Upd: Call(643) [Connected] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.481|200002| Trc|75|0006|: Ins: Call(644) [Ringing] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.492|200002| Trc|75|0006|: Upd: Call(644) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:55:53.509|200002| Trc|75|0006|: Upd: Call(644) [Connected] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.529|200002| Trc|75|0006|: Ins: Call(645) [Ringing] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:55:53.546|200002| Trc|75|0006|: Upd: Call(645) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:55:53.564|200002| Trc|75|0006|: Upd: Call(645) [Connected] DN=10005 IP=8888 EP=62300448009879077
    14.01.30 00:56:05.948|200002| Trc|75|0006|: Del: Call(643) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:56:05.954|200002| Trc|75|0006|: Del: Call(643) [Connected] DN=10005 IP=(null) EP=62300448009879077
    14.01.30 00:56:07.644|200002| Trc|75|0006|: Del: Call(644) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:56:07.650|200002| Trc|75|0006|: Del: Call(644) [Connected] DN=10005 IP=(null) EP=62300448009879077
    14.01.30 00:56:09.008|200002| Trc|75|0006|: Del: Call(645) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:56:09.016|200002| Trc|75|0006|: Del: Call(645) [Connected] DN=10005 IP=(null) EP=62300448009879077
    14.01.30 00:56:10.259|200002| Trc|75|0006|: Del: Call(642) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:56:10.264|200002| Trc|75|0006|: Del: Call(642) [Connected] DN=10005 IP=(null) EP=62300448009879077
    14.01.30 00:56:18.552|200002| Trc|75|0006|: Ins: Call(648) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:56:28.973|200002| Trc|75|0006|: Ins: Call(648) [Ringing] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:56:28.984|200002| Trc|75|0006|: Upd: Call(648) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:56:29.013|200002| Trc|75|0006|: Upd: Call(648) [Connected] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:57:03.780|200002| Trc|75|0006|: Del: Call(648) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:57:03.786|200002| Trc|75|0006|: Del: Call(648) [Connected] DN=10005 IP=(null) EP=6230037190991221
    14.01.30 00:57:05.544|200002| Trc|75|0006|: Ins: Call(649) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:57:15.927|200002| Trc|75|0006|: Ins: Call(649) [Ringing] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:57:15.938|200002| Trc|75|0006|: Upd: Call(649) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:57:15.944|200002| Trc|75|0006|: Upd: Call(649) [Connected] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:57:34.922|200002| Trc|75|0006|: Ins: Call(650) [Dialing] DN=8888 IP=(null) EP=8888
    14.01.30 00:57:45.322|200002| Trc|75|0006|: Ins: Call(650) [Ringing] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:57:45.344|200002| Trc|75|0006|: Upd: Call(650) [Connected] DN=8888 IP=10005 EP=8888
    14.01.30 00:57:45.353|200002| Trc|75|0006|: Upd: Call(650) [Connected] DN=10005 IP=8888 EP=6230037190991221
    14.01.30 00:58:08.372|200002| Trc|75|0006|: Ins: Call(650) [Ringing] DN=10005 IP=8888 EP=6230037190991221
    3CXQueueManager (cut):
    Code:
    4.01.30 00:55:13.236|100034| Trc|75|0007|: Call update(Insert): cid=641, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:23.647|100034| Trc|75|0007|: Call update(Insert): cid=641, dn=10005, internal=8888, external=62300448009879077, ac_stat=Ringing
    14.01.30 00:55:23.649|100034| Trc|75|0007|: Call update(Update): cid=641, dn=8888, internal=10005, external=8888, ac_stat=Connected
    14.01.30 00:55:23.653|100034| Trc|75|0007|: Call update(Update): cid=641, dn=10005, internal=8888, external=62300448009879077, ac_stat=Connected
    14.01.30 00:55:32.703|100039| Trc|75|0007|: Agent's 1006 phone is registered
    14.01.30 00:55:40.224|100034| Trc|75|0007|: Call update(Delete): cid=641, dn=8888, internal=(none), external=8888, ac_stat=Connected
    14.01.30 00:55:40.228|100034| Trc|75|0007|: Call update(Delete): cid=641, dn=10005, internal=(none), external=62300448009879077, ac_stat=Connected
    14.01.30 00:55:43.022|100005| Inf|30|0007|: Call(642) has been started
    14.01.30 00:55:43.022|100034| Trc|75|0007|: Call update(Insert): cid=642, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.045|100005| Inf|30|0007|: Call(643) has been started
    14.01.30 00:55:43.045|100034| Trc|75|0007|: Call update(Insert): cid=643, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.068|100005| Inf|30|0007|: Call(644) has been started
    14.01.30 00:55:43.068|100034| Trc|75|0007|: Call update(Insert): cid=644, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.129|100005| Inf|30|0007|: Call(645) has been started
    14.01.30 00:55:43.129|100034| Trc|75|0007|: Call update(Insert): cid=645, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.225|100005| Inf|30|0007|: Call(646) has been started
    14.01.30 00:55:43.225|100034| Trc|75|0007|: Call update(Insert): cid=646, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.313|100034| Trc|75|0007|: Call update(Delete): cid=646, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.408|100005| Inf|30|0007|: Call(647) has been started
    14.01.30 00:55:43.408|100034| Trc|75|0007|: Call update(Insert): cid=647, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:43.526|100034| Trc|75|0007|: Call update(Delete): cid=647, dn=8888, internal=(none), external=8888, ac_stat=Dialing
    14.01.30 00:55:53.388|100034| Trc|75|0007|: Call update(Insert): cid=642, dn=10005, internal=8888, external=62300448009879077, ac_stat=Ringing
    14.01.30 00:55:53.394|100034| Trc|75|0007|: Call update(Update): cid=642, dn=8888, internal=10005, external=8888, ac_stat=Connected
    14.01.30 00:55:53.410|100034| Trc|75|0007|: Call update(Update): cid=642, dn=10005, internal=8888, external=62300448009879077, ac_stat=Connected
    14.01.30 00:55:53.444|100034| Trc|75|0007|: Call update(Insert): cid=643, dn=10005, internal=8888, external=62300448009879077, ac_stat=Ringing
    14.01.30 00:55:53.453|100034| Trc|75|0007|: Call update(Update): cid=643, dn=8888, internal=10005, external=8888, ac_stat=Connected
    14.01.30 00:55:53.463|100034| Trc|75|0007|: Call update(Update): cid=643, dn=10005, internal=8888, external=62300448009879077, ac_stat=Connected
    14.01.30 00:55:53.490|100034| Trc|75|0007|: Call update(Insert): cid=644, dn=10005, internal=8888, external=62300448009879077, ac_stat=Ringing
    14.01.30 00:55:53.498|100034| Trc|75|0007|: Call update(Update): cid=644, dn=8888, internal=10005, external=8888, ac_stat=Connected
    14.01.30 00:55:53.510|100034| Trc|75|0007|: Call update(Update): cid=644, dn=10005, internal=8888, external=62300448009879077, ac_stat=Connected
    14.01.30 00:55:53.545|100034| Trc|75|0007|: Call update(Insert): cid=645, dn=10005, internal=8888, external=62300448009879077, ac_stat=Ringing
    14.01.30 00:55:53.551|100034| Trc|75|0007|: Call update(Update): cid=645, dn=8888, internal=10005, external=8888, ac_stat=Connected
    14.01.30 00:55:53.564|100034| Trc|75|0007|: Call update(Update): cid=645, dn=10005, internal=8888, external=62300448009879077, ac_stat=Connected
    14.01.30 00:56:05.956|100034| Trc|75|0007|: Call update(Delete): cid=643, dn=8888, internal=(none), external=8888, ac_stat=Connected
    14.01.30 00:56:05.960|100034| Trc|75|0007|: Call update(Delete): cid=643, dn=10005, internal=(none), external=62300448009879077, ac_stat=Connected
    14.01.30 00:56:07.653|100034| Trc|75|0007|: Call update(Delete): cid=644, dn=8888, internal=(none), external=8888, ac_stat=Connected
    14.01.30 00:56:07.656|100034| Trc|75|0007|: Call update(Delete): cid=644, dn=10005, internal=(none), external=62300448009879077, ac_stat=Connected
  10. Sergiy
    Dec 12, 2011
    15
    In addition:
    14:13:02.925 [CM503008]: Call(88): Call is terminated
    14:12:58.587 Currently active calls - 1: [88]
    14:12:57.812 Session 3919 of leg C:88.1 is confirmed
    14:12:57.610 [CM503007]: Call(88): Device joined: sip:1004@192.168.1.81:5062
    14:12:57.607 [CM503007]: Call(88): Device joined: sip:8888@192.168.1.195:50836;rinstance=46c51e1666255b17
    14:12:57.606 [MS210007] C:88.1:Answer provided. Connection(by pass mode): 192.168.1.81:11780(11781)
    14:12:57.604 [MS210001] C:88.2:Answer received. RTP connection[unsecure]: 192.168.1.81:11780(11781)
    14:12:57.603 Remote SDP is set for legC:88.2
    14:12:55.544 [CM505001]: Ext.1004: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.60.14.24] PBX contact: [sip:1004@192.168.1.131:5060]
    14:12:55.544 [CM503002]: Call(88): Alerting sip:1004@192.168.1.81:5062
    14:12:55.306 [CM503025]: Call(88): Calling Ext:Ext.1004@[Dev:sip:1004@192.168.1.81:5062]
    14:12:55.301 [MS210006] C:88.2:Offer provided. Connection(by pass mode): 192.168.1.195:40006(40007)
    14:12:55.256 [CM503004]: Call(88): Route 1: Ext:Ext.1004@[Dev:sip:1004@192.168.1.81:5062]
    14:12:55.255 [CM503010]: Making route(s) to <sip:1004@sip.xxxx.lan:5060>
    14:12:55.255 [MS210000] C:88.1:Offer received. RTP connection: 192.168.1.195:40006(40007)
    14:12:55.254 Remote SDP is set for legC:88.1
    14:12:55.249 [CM503001]: Call(88): Incoming call from Fax.8888 to <sip:1004@sip.xxxx.lan:5060>
    14:12:55.245 [CM500002]: Info on incoming INVITE:
    INVITE sip:1004@sip.xxxx.lan:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.195:50836;branch=z9hG4bK-d8754z-15445b57b3293126-1---d8754z-;rport=50836
    Max-Forwards: 70
    Contact: <sip:8888@192.168.1.195:50836;rinstance=46c51e1666255b17>
    To: <sip:1004@sip.xxxx.lan:5060>
    From: "8888"<sip:8888@sip.xxxx.lan:5060>;tag=556ae363
    Call-ID: ZWE0ZTc2N2ZlOTFlMzI4MWMwODJhNDI0YTc2YTQ2NGE.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="8888",realm="3CXPhoneSystem",nonce="414d535c09016a4760:00541ced7e8f13e3a98b63693cbcdfe0",uri="sip:1004@sip.xxxx.lan:5060",response="8cb18f1f49edfbcdd20c305c5f32922a",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 6.0.26523.0
    Content-Length: 0
    Now FAX service is down, but when I connect to 3CX with 8888 credentials, the system number 8888 becomes green :) I think the FAX number doesn't depend on FAX service...
  11. archie
    3CX Support
    Aug 18, 2006
    1,299
    I do not understand one thing:
    You've said you have the only outbound rule which starts with prefix '00'. They dialled '6230037190991221' and this number has been dialled outside. How could it be? Why all numbers they dial starts with '62300'? Does it have some meaning in your setup?
  12. Sergiy
    Dec 12, 2011
    15
    623 - access code for LDK that adds in outgoing rule automatically. Without it LDK doesn't pass any outgoing call.
  13. archie
    3CX Support
    Aug 18, 2006
    1,299
    Ok, now's clear. So we see translated number.
    Still, I would like to see original INVITE. Please, try to find backup of PBX log for 30-jan. You can zip (or rar) them all and send to me: arthur at 3cx dot com , for me to analyze.
  14. Sergiy
    Dec 12, 2011
    15
    If you have 3CX v10 you can connect with 8888 credentials and make any call passing any rule just with destination criteria.
    Here log of my call with 3CX softphone just 5 minutes ago:
    15:52:01.812 [CM503008]: Call(160): Call is terminated
    15:52:01.492 [CM102001]: Authentication failed for SipReq: REGISTER sip.sova.lan tid=ac1026263781 cseq=REGISTER contact=1049@192.168.1.171 / 424 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    15:51:55.292 Session 9416 of leg C:160.1 is confirmed
    15:51:55.104 [CM503007]: Call(160): Device joined: sip:1000@192.168.1.130:5060
    15:51:55.097 [CM503007]: Call(160): Device joined: sip:8888@192.168.1.195:49446;rinstance=5476c729f1372993
    15:51:55.097 [MS210007] C:160.1:Answer provided. Connection(by pass mode): 192.168.1.130:2048(2049)
    15:51:55.095 [MS210001] C:160.2:Answer received. RTP connection[unsecure]: 192.168.1.130:2048(2049)
    15:51:55.093 Remote SDP is set for legC:160.2
    15:51:55.093 [CM505003]: Provider:[LDK100] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:1000@192.168.1.131:5060]
    15:51:55.093 [CM503002]: Call(160): Alerting sip:1000@192.168.1.130:5060
    15:51:46.751 [CM503025]: Call(160): Calling VoIPline:62300371758286@(Ln.10005@LDK100)@[Dev:sip:1000@192.168.1.130:5060]
    15:51:46.748 [MS210006] C:160.2:Offer provided. Connection(by pass mode): 192.168.1.195:40006(40007)
    15:51:46.702 [CM503004]: Call(160): Route 1: VoIPline:62300371758286@(Ln.10005@LDK100)@[Dev:sip:1000@192.168.1.130:5060]
    15:51:46.701 [CM503010]: Making route(s) to <sip:00371758286@sip.xxxx.lan:5060>
    15:51:46.701 [MS210000] C:160.1:Offer received. RTP connection: 192.168.1.195:40006(40007)
    15:51:46.700 Remote SDP is set for legC:160.1
    15:51:46.695 [CM503001]: Call(160): Incoming call from Fax.8888 to <sip:00371758286@sip.xxxx.lan:5060>
    15:51:46.691 [CM500002]: Info on incoming INVITE:
    INVITE sip:00371758286@sip.xxxx.lan:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.195:49446;branch=z9hG4bK-d8754z-414e737103607d7a-1---d8754z-;rport=49446
    Max-Forwards: 70
    Contact: <sip:8888@192.168.1.195:49446;rinstance=5476c729f1372993>
    To: <sip:00371758286@sip.xxxx.lan:5060>
    From: "8888"<sip:8888@sip.xxxx.lan:5060>;tag=1c573250
    Call-ID: NzNiMTdlZWIwNDNhNDM2Zjk5MzA1NTdhOWQwMDVmMmI.
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="8888",realm="3CXPhoneSystem",nonce="414d535c0901817223:f3636fa8a829d03b663317410ac992cf",uri="sip:00371758286@sip.xxxx.lan:5060",response="86ddc1d7cb75c4dcfa043092a47ba09f",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    If you still want full log, please provide filename.
