Fax PDF Output broken
Discussion in '3CX Phone System - General' started by d.blum, Mar 26, 2018.
  1. d.blum
    Oct 13, 2015
    9
    I have a Problem with the Fax Server.
    If somewone sends us an Fax with multiple sites, the Output in the PDF is broken.
    I attached the original PDF, the received PDF and the single Pictures from tif File.
    How can I fix this?
    Thanks in advance.
    Dominik
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    What exactly does this mean?
    Are you sure the sending side is sending the complete document before being disconnected? Is the sending side sending electronically or using analog fax?
    #2 craigreilly, Mar 26, 2018
  3. d.blum
    Oct 13, 2015
    9
    I tested via simple-Fax.de and via analog.
    If i Send the Fax to the analog device via ata , the Fax is correct
  4. cornholio21
    Dec 4, 2017
    8
    Looks like missed data...
    I know this behavior when network is laggy/unstable on the way to SIP trunk.
    Also this happens when a SIP Provider doesn't support T.38 ;)
    Maybe try monitoring your latency to the sip provider?
    Regards
    Anton
  5. d.blum
    Oct 13, 2015
    9
    But this also Happens if I send an fax from the local analog fax via ata to the 3CX fax server.
  6. d.blum
    Oct 13, 2015
    9
    Has someone another Idea?
