fax problems
Discussion in '3CX Phone System - General' started by UdoBo, Feb 14, 2008.
  1. UdoBo
    Dec 10, 2007
    5
    11:35:27.859 Call::Terminate [CM503008]: Call(2): Call is terminated
    11:35:27.828 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10001 forwards to DN:
    11:35:27.687 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10001 forwards to DN:
    11:35:27.562 Call::RouteFailed [CM503014]: Call(2): Attempt to reach [sip:pbx1.ath.cx:5062] failed. Reason: Not Found
    11:35:27.562 CallCtrl::eek:nSelectRouteReq [CM503013]: Call(2): No known route to target: [sip:pbx1.ath.cx:5062]
    11:35:27.406 Line::printEndpointInfo [CM505002]: Gateway:[953153] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4552 2BIS EUI MxSF v3.2.8.45 00A0BA0340CE R4.2 2007-12-03 SIP] Transport: [sip:192.168.101.20:5062]
    11:35:27.406 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10001 forwards to DN:
    11:35:27.265 CallCtrl::eek:nIncomingCall [CM503001]: Call(2): Incoming call from 2163953155@(Ln.10001@953153) to [sip:pbx1.ath.cx:5062]
    11:35:27.250 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:10001 forwards to DN:
    I get no faxes , can someone help?
  2. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    He Udobo
    do you have any rule for inbound calls??? any destination?? you can define it on the line. thats very important. that the destination also exist.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    312
    hi udo,
    Ensure you have enabled fax on the patton as per the FAQ
    Else contact our support dept, since you are partner...
