FAX Server and forward fax on different email
Discussion in '3CX Phone System - General' started by davidepet, Oct 17, 2008.
  1. davidepet
    Sep 12, 2008
    5
    Hello everyone,
    on the receiving faxes with 3CX, we must use the Windows Server FAX: and then installing 3CX be made on a workstation running Windows Server?
    You can send faxes to different email addresses?
    In that case, we need a dedicated line for each recipient email?
    Thank you,
    David.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    hi
    What you can do is the following for now
    use the concept of DID's on your line if you have available:
    Set for example a number of DID's that each forward the call to the fax to email of extension XXX
    1 did will forward to the fax extension which then forwards to email of A
    2nd did will forward to the fax extension which then forwards to email of B
    etc etc
    FOR EXAMPLE:
    So you can publish the following -
    For accounting faxes send to this number 22222221 which is a did associated to the main line number 22222220 that forwards to ext 100 which is accounts@company.com. That fax will go to the user's mailbox that works in your accounts dept
  3. aabbcc
    Oct 3, 2008
    5
    Hi there
    I am also trying to receive faxes with 3cx fax server, but failed to get faxes.
    I have a DID number 81234567 which is used to receive faxes. I try to follow the manual, as below.
    1. Voice Mail & Fax delivery settings
    Fax Delivery Settings - set as default, FAX number is 888, and FAX Defult Delivery Address is my own email account.
    2. Configure the DID number
    Go to 'Route FAX Calls' -> 'All Calls'.
    However, it failed to receive faxes.
    Any advice?
    Thank you
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    What Are you using to receive faxes? Voip Provider or a Gateway?
    Make and model needs to be specified -
    If it is a VOip Provider there are some Voip Providers that are T38 compliant that work with 3CX.
    You have to check whether the entity you are using understands T38.
  5. aabbcc
    Oct 3, 2008
    5
    Thanks for your help, Nicky.
    For the choice between gateway and voip provider, do you mean the selection under the "Source" of the DID number.
    (DID number -> Source -> VOIP Gateway or VOIP Provider).
    Normally, do gateways, such as Patton and Vegastream, support FAX?
  6. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Yes, Patton and Vega do support fax.
    They are both reliable brands for faxing be it with analog or BRI / PRI lines.
    NB. If opting for Patton please use foirmware version 4.2 dated March 2008. Do not use any of the more recent firmwares for the time being.
