Fax Server Extension (888) Stopped Working
Discussion in '3CX Phone System - General' started by interactive9, Jun 8, 2017.
  1. interactive9
    Oct 26, 2015
    22
    Our fax extension has stopped working, it's worked fine since implementation up untill approx three weeks ago.
    Should I hear the normal fax noises when dialling the fax extension internally? If so this isn't happening, it just drops the call straight away.
    Fully upto date.
  2. ivank
    3CX Support
    Jan 4, 2017
    54
    6
    Is 888 shown as registered in the system extensions?
    Can you provide activity log for an incoming fax call to 888?
    Have you tried restarting 3CX IVR service?
    #2 ivank, Jun 8, 2017
  3. StefanW
    Jun 2, 2009
    1,222
    93
    No, T38 fax server operate on a digital base and not on audio, so calling it will make no audio tone unless G711 is activated...
