Fax-server extension always busy
Discussion in '3CX Phone System - General' started by MatsW, May 1, 2009.
  1. MatsW
    Mar 10, 2009
    50
    I have 3CX server v7.1.6391.0 with a 3CXPSMINI license installed on a XP Pro host. The fax server has extension 88, and one of my lines is configured to always "Send fax to email of extension" to default fax extension. But when I call the line I always gets busy. The log says
    09:57:59.447 [CM503008]: Call(21): Call is terminated
    09:57:59.432 [CM503008]: Call(21): Call is terminated
    09:57:58.416 [CM503007]: Call(21): Device joined: sip:88@192.168.100.23:5100;user=phone
    09:57:58.369 [CM503007]: Call(21): Device joined: sip:SIP_5FM@85.195.3.109
    09:57:58.338 [CM503002]: Call(21): Alerting sip:88@192.168.100.23:5100;user=phone
    09:57:58.197 [CM503004]: Call(21): Calling: @[Dev:sip:88@192.168.100.23:5100;user=phone]
    09:57:58.182 [CM503010]: Making route(s) to <sip:88@192.168.100.23:5060;user=fax>
    09:57:58.182 [CM505003]: Provider:[NETatONCE privat] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.100.23:5060]
    09:57:58.135 [CM503001]: Call(21): Incoming call from 084456921@(Ln.10002@NETatONCE privat) to <sip:88@192.168.100.23:5060;user=fax>
    09:57:58.119 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10002 forwards to Fax:88
    I also get busy-tone if I call from a local extension to extension-88
    What could cause the fax-server to even not pick up the line?
  2. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Fax service requires t.38 transmissions. Check if your provider supports FOIP or run wireshark and check INVITEs sent from your provider. Details here:
    http://wiki.3cx.com/Home/technical-documentation-dash/fax-over-ip
  3. ciscotech2007
    Jan 27, 2009
    94
    Review INBOUND and OUTBOUND fax configuration of 3CX server and modules.
    http://www.3cx.com/manual/3CXPhoneSystemManual7/phone-system67.html
