Fax server not working
Discussion in '3CX Phone System - General' started by djboxny, Aug 16, 2010.
  1. djboxny
    Aug 8, 2010
    42
    I installed the Fax server, and set the corresponding DID number that i got from Skype SIP, That number goes dirrectly to the fax, The fax server apparently picks up when someone call the fax line number but nothing is heard at all. and according to the fax machines i tried it with they say that No one answered.
    here is the Berbose Logs
    02:26:02.781 [CM503008]: Call(1): Call is terminated
    02:26:01.375 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:26:01.375 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:26:01.375 Remote SDP is set for legC:1.1
    02:26:01.218 Remote SDP is set for legC:1.2
    02:25:59.625 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:59.625 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:59.625 Remote SDP is set for legC:1.1
    02:25:59.468 Remote SDP is set for legC:1.2
    02:25:57.875 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:57.875 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:57.875 Remote SDP is set for legC:1.1
    02:25:57.718 Remote SDP is set for legC:1.2
    02:25:56.125 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:56.125 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:56.125 Remote SDP is set for legC:1.1
    02:25:55.968 Remote SDP is set for legC:1.2
    02:25:54.375 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:54.375 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:54.375 Remote SDP is set for legC:1.1
    02:25:54.218 Remote SDP is set for legC:1.2
    02:25:52.625 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:52.625 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:52.609 Remote SDP is set for legC:1.1
    02:25:52.468 Remote SDP is set for legC:1.2
    02:25:50.875 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:50.875 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:50.875 Remote SDP is set for legC:1.1
    02:25:50.718 Remote SDP is set for legC:1.2
    02:25:49.125 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:49.125 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:49.109 Remote SDP is set for legC:1.1
    02:25:48.968 Remote SDP is set for legC:1.2
    02:25:47.375 [MS210007] C:1.2:Answer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:47.375 [MS210001] C:1.1:Answer received. RTP connection[unsecure]: 63.209.144.201:26918(26919)
    02:25:47.375 Remote SDP is set for legC:1.1
    02:25:47.218 Remote SDP is set for legC:1.2
    02:25:46.046 Session 116 of leg C:1.1 is confirmed
    02:25:45.750 [CM503007]: Call(1): Device joined: sip:888@public.ip:5100;user=phone
    02:25:45.734 [CM503007]: Call(1): Device joined: sip:99051000114913@sip.skype.com:5060
    02:25:45.734 [MS210007] C:1.1:Answer provided. Connection(by pass mode): public.ip:10002(10003)
    02:25:45.734 [MS210001] C:1.2:Answer received. RTP connection[unsecure]: public.ip:10002(10003)
    02:25:45.734 Remote SDP is set for legC:1.2
    02:25:45.734 [CM503002]: Call(1): Alerting sip:888@public.ip:5100;user=phone
    02:25:45.656 [CM503025]: Call(1): Calling @[Dev:sip:888@public.ip:5100;user=phone]
    02:25:45.656 [MS210006] C:1.2:Offer provided. Connection(by pass mode): 63.209.144.201:26918(26919)
    02:25:45.625 [CM503004]: Call(1): Route 1: @[Dev:sip:888@public.ip:5100;user=phone]
    02:25:45.625 [CM503010]: Making route(s) to <sip:888@public.ip:5060;user=fax>
    02:25:45.625 [MS210000] C:1.1:Offer received. RTP connection: 63.209.144.201:26918(26919)
    02:25:45.625 Remote SDP is set for legC:1.1
    02:25:45.609 [CM505003]: Provider:[Skype SIP - 2CH In handler] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [SipGW 0.3.19] PBX contact: [sip:99051000114913@public.ip:5060]
    02:25:45.609 [CM503001]: Call(1): Incoming call from 16465332025@(Ln.10001@Skype SIP - 2CH In handler) to <sip:888@public.ip:5060;user=fax>
    02:25:45.421 [CM503012]: Inbound out-of-office hours rule (12014674775) for 10001 forwards to Fax:888
    02:25:45.421 Looking for inbound target: called=12014674775; caller=16465332025
    02:25:45.421 [CM500002]: Info on incoming INVITE:
    INVITE sip:12014674775@public.ip:5060;rinstance=20cd16af2d3b54ea;transport=udp SIP/2.0
    Via: SIP/2.0/UDP 63.209.144.201:5060;branch=z9hG4bK-60596-4c68d9e3-e66479d5-5aedbe33
    Max-Forwards: 30
    Contact: <sip:16465332025@63.209.144.201:5060;transport=udp>
    To: <sip:12014674775@sip.skype.com>
    From: <sip:16465332025@sip.skype.com>;tag=c990d13f-13c4-4c68d9e3-e66479d5-76b781a2
    Call-ID: CXC-56-67081830-c990d13f-13c4-4c68d9e3-e66479d5-6489c584
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE
    User-Agent: SipGW 0.3.19
    Content-Length: 0
    02:25:32.328 Currently active calls [none]
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Skype does not support fax, especially T38 faxing which is what the 3cx fax server uses.
    If you want to receive faxes using the 3cx fax server then you need a VOIP provider that supports it. We use Broadvox for us and our customers.
  3. djboxny
    Aug 8, 2010
    42
    Ok, Does Xeloq Support it?
  4. djboxny
    Aug 8, 2010
    42
    i there a way to test internaly if the fax service in working on the server. Like dailing the extention of the fax server to hear a tone?
  5. abc123
    Nov 9, 2009
    712
    Short answer - no.
    Faxing over IP (FOIP) is a different protocol to VOIP.
    Basically when the call comes in to the 3cx server and the 3cx knows it is to go to a fax (T38) it sends a reinvite message back saying "contact me again on this number using the t38 protocol". As sip phones do not know what t38 is then you cannot dial the extension internally.
    The fax server does work. We have it on one real estate office where they have 24 DIDs for fax - one for each agent. If the fax server has a problem then it will show in the windows event logs if the service is a problem or the 3cx logs if it is a configuration problem. But other than the few well documented changes which take about 10 minutes to set up - it works out of the box.
    I do not believe xeloq uses t38. We successfully use Broadvox for our sip trunks and they use t38. I will be happy to give you some contact information and setup.
  6. djboxny
    Aug 8, 2010
    42
    I Contacted Broadvox already and i am getting their services. How do i connect my Laptop to the fax server to send faxes. The turorial here seems outdated.
  7. djboxny
    Aug 8, 2010
    42
    can someone please tell me Step by step how to install and configure Faxing on windows server 2003 so other computers on the network can use it. I already have a provider that supports it. I cant figure it out even tried this
    http://www.3cx.com/blog/docs/microsoft-fax-2003/ to no avail. Please help
  8. abc123
    Nov 9, 2009
    712
    3CX does not support this any longer. There used to be a fax sending module in an older version but that is no longer the case. There are rumors that they may be a new one in the future, but I doubt this is high on their priority list.
    To send a fax using Windows Fax Server, you will need a card in the server to connect to a PSTN network.
  9. djboxny
    Aug 8, 2010
    42
    Ok i just got broadvox. i tried sending a fax to it from a analog fax machine connected in my house and it dint work.
    SMTP server is working correctly. DID is routing to fax.
    this is the logs
    22:53:11.495 [CM503008]: Call(26): Call is terminated
    22:53:09.589 [CM503007]: Call(26): Device joined: sip:888@public.ip:5100;user=phone
    22:53:09.589 [CM503007]: Call(26): Device joined: sip:9738704380@fs2.broadvox.net:5060
    22:53:09.573 [CM503002]: Call(26): Alerting sip:888@public.ip:5100;user=phone
    22:53:09.495 [CM503025]: Call(26): Calling @[Dev:sip:888@public.ip:5100;user=phone]
    22:53:09.448 [CM503004]: Call(26): Route 1: @[Dev:sip:888@public.ip:5100;user=phone]
    22:53:09.448 [CM503010]: Making route(s) to <sip:888@192.168.1.145:5060;user=fax>
    22:53:09.417 [CM505003]: Provider:[Broadvox GO! SIP] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9738704380@public.ip:5060]
    22:53:09.402 [CM503001]: Call(26): Incoming call from 2017199243@(Ln.10002@Broadvox GO! SIP) to <sip:888@192.168.1.145:5060;user=fax>
    22:53:09.355 [CM503012]: Inbound out-of-office hours rule (Broadvox Fax Line) for 10002 forwards to Fax:888
    22:37:16.152 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@173.220.110.114:58118;rinstance=29CF3CC1/100,sip:100@192.168.1.141:11396;rinstance=6536BD0F099594ABEE3E/100]
    22:37:13.558 [CM504001]: Ext.100: new contact is registered. Contact(s): [sip:100@192.168.1.141:11396;rinstance=6536BD0F099594ABEE3E/100]
    22:36:44.370 [CM504001]: Ext.101: new contact is registered. Contact(s): [sip:101@192.168.1.134:49651;rinstance=5adfb23a56ac6441/101]
    21:48:55.183 [CM504002]: Ext.101: a contact is unregistered. Contact(s): []
    21:43:01.933 [CM504004]: Registration succeeded for: 10002@Broadvox GO! SIP
    21:43:01.652 [CM504003]: Sent registration request for 10002@Broadvox GO! SIP
    21:42:10.027 [CM504007]: Next attempt to register 10002@Broadvox GO! SIP is scheduled in 5 minute
    21:42:10.011 [CM504005]: Registration failed for: 10002@Broadvox GO! SIP; Cause: 403 Forbidden; from IP:208.93.224.229:5060
    21:42:09.683 [CM504003]: Sent registration request for 10002@Broadvox GO! SIP
    21:41:07.777 [CM504008]: Fax Service: registered as sip:888@public.ip:5060 with contact sip:888@public.ip:5100;user=phone
    21:41:05.917 [CM504010]: Fax Service: unregistered contact sip:
    21:39:51.777 [CM503008]: Call(25): Call is terminated
    21:39:49.855 [CM503007]: Call(25): Device joined: sip:888@192.168.1.145:5100;user=phone
    21:39:49.855 [CM503007]: Call(25): Device joined: sip:9738704380@fs2.broadvox.net:5060
    21:39:49.839 [CM503002]: Call(25): Alerting sip:888@192.168.1.145:5100;user=phone
    21:39:49.745 [CM503025]: Call(25): Calling @[Dev:sip:888@192.168.1.145:5100;user=phone]
    21:39:49.683 [CM503004]: Call(25): Route 1: @[Dev:sip:888@192.168.1.145:5100;user=phone]
    21:39:49.683 [CM503010]: Making route(s) to <sip:888@192.168.1.145:5060;user=fax>
    21:39:49.683 [CM505003]: Provider:[Broadvox GO! SIP] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9738704380@public.ip:5060]
    21:39:49.683 [CM503001]: Call(25): Incoming call from 6465332025@(Ln.10002@Broadvox GO! SIP) to <sip:888@192.168.1.145:5060;user=fax>
    21:39:49.652 [CM503012]: Inbound out-of-office hours rule (Broadvox Fax Line) for 10002 forwards to Fax:888
  10. djboxny
    Aug 8, 2010
    42
    i just spoke to Broadvox. They sampled a fax call then told me that 3CX Sends t38 ring invite, broadvox sends 200 ok in t38 codec and as soon as the they send the 200 ok 3cx terminates the call. Y is 3CX not alowwing the connection to finish.????
  11. abc123
    Nov 9, 2009
    712
    Have you set up everything in 3cx server according to the instructions?
    Did you change the two templates? Do you have a static public ip for the 3cx?
    Can you take a wireshark capture so we can see where it is going wrong?
  12. djboxny
    Aug 8, 2010
    42
    Yes i have a Static IP, with No firewall at all. here is the verbose logs
    10:55:09.230 [CM503008]: Call(2): Call is terminated
    10:55:09.105 Remote SDP is set for legC:2.1
    10:55:08.698 Remote SDP is set for legC:2.2
    10:55:07.355 Session 159 of leg C:2.1 is confirmed
    10:55:07.214 [CM503007]: Call(2): Device joined: sip:888@192.168.1.145:5100;user=phone
    10:55:07.214 [CM503007]: Call(2): Device joined: sip:9738704380@fs2.broadvox.net:5060
    10:55:07.214 [MS210007] C:2.1:Answer provided. Connection(by pass mode): 192.168.1.145:10002(10003)
    10:55:07.214 [MS210001] C:2.2:Answer received. RTP connection[unsecure]: 192.168.1.145:10002(10003)
    10:55:07.214 Remote SDP is set for legC:2.2
    10:55:07.214 [CM503002]: Call(2): Alerting sip:888@192.168.1.145:5100;user=phone
    10:55:07.167 [CM503025]: Call(2): Calling @[Dev:sip:888@192.168.1.145:5100;user=phone]
    10:55:07.167 [MS210006] C:2.2:Offer provided. Connection(by pass mode): 64.158.162.71:24844(24845)
    10:55:07.120 [CM503004]: Call(2): Route 1: @[Dev:sip:888@192.168.1.145:5100;user=phone]
    10:55:07.120 [CM503010]: Making route(s) to <sip:888@192.168.1.145:5060;user=fax>
    10:55:07.120 [MS210000] C:2.1:Offer received. RTP connection: 64.158.162.71:24844(24845)
    10:55:07.120 Remote SDP is set for legC:2.1
    10:55:07.120 [CM505003]: Provider:[Broadvox GO! SIP] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Broadvox Fusion] PBX contact: [sip:9738704380@public.ip:5060]
    10:55:07.120 [CM503001]: Call(2): Incoming call from 2017199243@(Ln.10002@Broadvox GO! SIP) to <sip:888@192.168.1.145:5060;user=fax>
    10:55:07.105 [CM503012]: Inbound out-of-office hours rule (Broadvox Fax Line) for 10002 forwards to Fax:888
    10:55:07.105 Looking for inbound target: called=9738704381; caller=2017199243
    10:55:07.089 [CM500002]: Info on incoming INVITE:
    INVITE sip:9738704381@public.ip:5060 SIP/2.0
    Via: SIP/2.0/UDP 208.93.224.229;rport=5060;branch=z9hG4bKaB1yBt5KFrQ0j
    Max-Forwards: 69
    Contact: <sip:2017199243@208.93.224.229:5060>
    To: <sip:9738704381@public.ip:5060>
    From: "2017199243"<sip:2017199243@208.93.224.229>;tag=62gBmyvtyX4FQ
    Call-ID: e22ae6e1-2f88-122e-eda0-a4badb456be6
    CSeq: 1288234 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY
    Supported: timer, precondition, path, replaces
    User-Agent: Broadvox Fusion
    Allow-Events: talk, hold, refer
    Privacy: none
    P-Asserted-Identity: "2017199243" <sip:2017199243@208.93.224.229>
    Content-Length: 0
    X-FS-Support: update_display
    10:54:55.277 Currently active calls [none]
  13. abc123
    Nov 9, 2009
    712
    Those logs dont help as we need to see the sip information being sent and received.
    Before we go into that, can you confirm you have set up the 3cx fax in accordance with the instructions here
    http://www.3cx.com/blog/docs/fax-nat-traversal/
  14. djboxny
    Aug 8, 2010
    42
    i just did that, does that require all systems restarted?
  15. djboxny
    Aug 8, 2010
    42
    this is the wiresharck capture of a 10 packet fax call trying to come on. I have in the fax server settings to bind to the Static IP is that correct.
    No. Time Source Destination Protocol Info
    88397 93.234660 208.93.226.213 public.ip SIP/SDP Request: INVITE sip:9738704381@public.ip:5060, with session description
    Frame 88397: 1066 bytes on wire (8528 bits), 1066 bytes captured (8528 bits)
    Ethernet II, Src: Cisco_13:82:b8 (a4:0c:c3:13:82:b8), Dst: HewlettP_6d:22:6e (00:0f:20:6d:22:6e)
    Internet Protocol, Src: 208.93.226.213 (208.93.226.213), Dst: public.ip (public.ip)
    User Datagram Protocol, Src Port: sip (5060), Dst Port: sip (5060)
    Session Initiation Protocol
    88445 93.360389 public.ip 208.93.226.213 SIP Status: 100 Trying
    Frame 88445: 337 bytes on wire (2696 bits), 337 bytes captured (2696 bits)
    Ethernet II, Src: HewlettP_6d:22:6e (00:0f:20:6d:22:6e), Dst: Cisco_13:82:b8 (a4:0c:c3:13:82:b8)
    Internet Protocol, Src: public.ip (public.ip), Dst: 208.93.226.213 (208.93.226.213)
    88513 93.472774 public.ip 208.93.226.213 SIP/SDP Status: 200 OK, with session description
    Frame 88513: 766 bytes on wire (6128 bits), 766 bytes captured (6128 bits)
    88705 93.586620 208.93.226.213 public.ip SIP Request: ACK sip:9738704381@public.ip:5060
    Frame 88705: 436 bytes on wire (3488 bits), 436 bytes captured (3488 bits)
    88718 93.626878 64.152.60.71 public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0xD1753E18, Seq=0, Time=0, Mark
    Frame 88718: 214 bytes on wire (1712 bits), 214 bytes captured (1712 bits)
    Internet Protocol, Src: 64.152.60.71 (64.152.60.71), Dst: public.ip (public.ip)
    User Datagram Protocol, Src Port: 25138 (25138), Dst Port: documentum (10002)
    Real-Time Transport Protocol
    90049 94.967050 public.ip 208.93.226.213 SIP/SDP Request: INVITE sip:2017199243@208.93.226.213:5060, in-dialog, with session description
    Frame 90049: 955 bytes on wire (7640 bits), 955 bytes captured (7640 bits)
    90154 95.023679 208.93.226.213 public.ip SIP Status: 100 Trying
    Frame 90154: 402 bytes on wire (3216 bits), 402 bytes captured (3216 bits)
    90371 95.250190 208.93.226.213 public.ip SIP/SDP Status: 200 OK, with session description
    Frame 90371: 961 bytes on wire (7688 bits), 961 bytes captured (7688 bits)
    90407 95.354827 public.ip 208.93.226.213 SIP Request: ACK sip:2017199243@208.93.226.213:5060
    Frame 90407: 498 bytes on wire (3984 bits), 498 bytes captured (3984 bits)
    90431 95.467993 public.ip 208.93.226.213 SIP Request: BYE sip:2017199243@208.93.226.213:5060
    Frame 90431: 498 bytes on wire (3984 bits), 498 bytes captured (3984 bits)
    90444 95.527015 208.93.226.213 public.ip SIP Status: 200 OK
    Frame 90444: 533 bytes on wire (4264 bits), 533 bytes captured (4264 bits)
  16. djboxny
    Aug 8, 2010
    42
    ok this is a Update,
    in the fax server setting i have set the network interface to the local IP of the server instead of the Static one.
    Now if i dial the fax server extention from a internal Extention i hear the Fax tones and sounds. wich means it is working. But anyone dialing into the fax DID gets the same disconnection.
  17. djboxny
    Aug 8, 2010
    42
    UPDATEE!!!
    I have succesfully received a fax BUT only thru a grandstream handytone 502 and a analog fax machine.
    here is the setup
    Broadvox VOIP --> 3cx --> Handytone ATA 502 (t38 pass thru mode) --> Analog Fax machine.
    I worked great. But what i really want is the 3cx Fax server to work.
  18. abc123
    Nov 9, 2009
    712
    You need to restart the fax server to make the changes.
    I dont see any t38 requests coming in or out.
    Restart 3cx if you can and then run wireshark and see if you can get any t38 requests.
    EDIT: I missed P2 of the thread with the latest updates from you.
    In the fax template configs should make NAT support true and uncomment the sip port 5100 (make sure open on firewall too).
    Then in the other template you should need to make the kind of t38 transport UDP and then put the local ip address as your internal ip and the (nat) local media ip address as your public static ip address.
    Then go into the advance settings , custom parameters and make Faxdirectsdp set to 1.
    Then restart the 3cx and it should all work.
  19. djboxny
    Aug 8, 2010
    42
    OK, According to Broadvox wireshark capture this is whats happening.
    a Fax comes into the fax line did then it is sent to the 3cx fax server, the fax server requests port 10002 so broadvox acknowledges it and tries to send the media thru that port. BUT according to broadvox port 10002 is unreachable here is the logs
    1 0.000000 208.93.224.229 my.public.ip SIP/SDP Request: INVITE sip:9738704381@my.public.ip:5060, with session description
    2 0.161303 my.public.ip 208.93.224.229 SIP Status: 100 Trying
    3 0.267339 my.public.ip 208.93.224.229 SIP/SDP Status: 200 OK, with session description
    4 0.268241 208.93.224.229 my.public.ip SIP Request: ACK sip:9738704381@my.public.ip:5060
    5 0.387340 208.93.224.229 my.public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0x46BDD664, Seq=41360, Time=39944
    6 0.427193 208.93.224.229 my.public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0x46BDD664, Seq=41361, Time=40264
    7 0.447356 my.public.ip 208.93.224.229 ICMP Destination unreachable (Port unreachable)
    8 0.447424 208.93.224.229 my.public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0x46BDD664, Seq=41362, Time=40424
    9 0.467272 208.93.224.229 my.public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0x46BDD664, Seq=41363, Time=40584
    10 0.480571 my.public.ip 208.93.224.229 ICMP Destination unreachable (Port unreachable)
    11 0.487397 208.93.224.229 my.public.ip RTP PT=ITU-T G.711 PCMU, SSRC=0x46BDD664, Seq=41364, Time=40744
    12 0.500568 my.public.ip 208.93.224.229 ICMP Destination unreachable (Port unreachable)
    and after many tries they get this
    140 1.769070 my.public.ip 208.93.224.229 SIP/SDP Request: INVITE sip:2017199243@208.93.224.229:5060, in-dialog, with session description
    141 1.769578 208.93.224.229 my.public.ip SIP Status: 100 Trying
    142 1.787036 my.public.ip 208.93.224.229 ICMP Destination unreachable (Port unreachable)
    145 41.865898 my.public.ip 208.93.224.229 SIP Request: BYE sip:2017199243@208.93.224.229:5060
    146 41.867084 208.93.224.229 my.public.ip SIP Status: 200 OK
    147 41.867199 208.93.224.229 my.public.ip SIP Status: 487 Session Terminated
    148 41.925557 my.public.ip 208.93.224.229 SIP Request: ACK sip:2017199243@208.93.224.229:5060
    media port info audio 10002 RTP/AVP 0
  20. abc123
    Nov 9, 2009
    712
    Do you have those ports open and forwarded in your router/firewall?
    Why is it 10002? It should be 10000. Did you change it in the 3CX in_session.cfg? I dont know if this makes a difference or not.
    But either you have the wrong thing being sent from the config or the port is not open on your end.
