Fax Server not working
Discussion in '3CX Phone System - General' started by gehri, May 18, 2017.
  1. gehri
    Jan 28, 2015
    12
    i'm facing since 3 weeks with the ingoing fax server.
    When i send a fax to the fax DID (in our case *011) there's no fax tone and the negotiation phase remains till a the user hangs up because of the busy tone.
    See attached logs (3CX IVR and Activity Log).
    What can i do?
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    what version of 3cx are you using ? I'm having fax issues with the 15.5 beta but haven't yet confirmed it's a 3cx issue ...
  3. gehri
    Jan 28, 2015
    12
    Using 15.0.62928.5.
    Don't want to install over the beta, because it's a production site.
    Any idea?
  4. StefanW
    Jun 2, 2009
    1,217
    89
    there is no fax tone as the fax server you hare having is "digitial" or in tech terms T.38. So I assume that the provider you use can not process t.38. You can have a classic fax tone in 15.5 beta as the fax server contains the option to be in audio... give it a try...
  5. gehri
    Jan 28, 2015
    12
    Hi StefanW,
    thanks for the information.
    A technician from our SIP Trunk provider (Sunrise Switzerland) told me T.38 is already on as the primary fax protocol.
    So i don't really know what could be the issue.
