I did as you suggested.
The log for the initial suggestion is as follows:
16:57:55.476 [CM503008]: Call(84): Call is terminated
16:57:38.961 [CM503007]: Call(84): Device joined: sip:
[email protected]:5100;user=phone
16:57:38.960 [CM503007]: Call(84): Device joined: sip:
[email protected]:5060
16:57:38.900 [CM503025]: Call(84): Calling @[Dev:sip:
[email protected]:5100;user=phone]
16:57:38.870 [CM503004]: Call(84): Route 1: @[Dev:sip:
16:57:38.868 [CM505003]: Provider:[NexVortex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
[email protected]:5060]
16:57:38.864 [CM503001]: Call(84): Incoming call from +19564254764@(Ln.10001@NexVortex) to
<sip:[email protected]:5060;user=fax>16:57:38.845 [CM503012]: Inbound any hours rule (19564124113*) for 10001 forwards to Fax:888
16:57:19.829 [CM503008]: Call(83): Call is terminated
16:57:03.670 [CM504004]: Registration succeeded for: 10001@NexVortex
16:57:03.389 [CM504003]: Sent registration request for 10001@NexVortex
16:57:03.373 [EC100007]: External application is connected: application
olly:0/InterfaceWindows local:127.0.0.1:5482 remote:127.0.0.1:56410
16:56:36.416 [CM503007]: Call(83): Device joined: sip:
16:56:26.167 IP(s) removed:[192.168.20.250]
As you can see this did not work.
I then tried the second suggestion and left disabled and restarted all. here is the log:
17:11:19.649 [CM505003]: Provider:[NexVortex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
17:11:14.548 [MS211000] C:1.1: 4.55.5.130:27160 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
17:11:03.176 [CM504001]: Ext.102: new contact is registered. Contact(s): [sip:
[email protected]:52392;rinstance=cac51ea1017328eb/102]
17:10:56.510 [CM504001]: Ext.118: new contact is registered. Contact(s): [sip:
[email protected]:5060/118]
17:10:49.922 [CM503007]: Call(1): Device joined: sip:
[email protected]:40600;rinstance=586970e6227bbbe9
17:10:49.921 [CM503007]: Call(1): Device joined: sip:
17:10:49.717 [CM503025]: Call(1): Calling Ext:Ext.800@[Dev:sip:
[email protected]:40600;rinstance=586970e6227bbbe9]
17:10:49.678 [CM503004]: Call(1): Route 1: Ext:Ext.800@[Dev:sip:
17:10:49.676 [CM505003]: Provider:[NexVortex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
17:10:49.672 [CM503001]: Call(1): Incoming call from +19562446762@(Ln.10001@NexVortex) to <sip:
[email protected]:5060>
17:10:49.617 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:800
17:10:44.892 [CM504001]: Ext.107: new contact is registered. Contact(s): [sip:
[email protected]:5060;transport=udp/107]
17:10:21.651 [CM504001]: Ext.112: new contact is registered. Contact(s): [sip:
[email protected]:5060/112]
17:10:15.699 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=1e73391a5afdc56e/IVRForward]
17:10:15.610 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=1497f049fb0ac94f/EndCall]
17:10:15.603 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=586970e6227bbbe9/800]
17:10:15.597 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=2751f16b6e017d08/999]
17:09:57.700 [CM504001]: Ext.114: new contact is registered. Contact(s): [sip:
[email protected]:5060;transport=udp/114]
17:09:53.238 [CM504004]: Registration succeeded for: 10001@NexVortex
17:09:52.880 [CM504003]: Sent registration request for 10001@NexVortex
17:09:52.770 IP(s) added:[192.168.0.250]
17:09:50.930 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=04e239a867291f77/*1]
17:09:50.836 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=1afaad97cc5e7939/*0]
17:09:50.820 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=1bf24407aac53df8/*777]
17:09:45.658 [EC100007]: External application is connected: application
olly:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:56954
17:09:45.105 [CM504008]: Fax Service: registered as sip:
[email protected]:5060 with contact sip:
17:09:45.074 [CM504004]: Registration succeeded for: 10001@NexVortex
17:09:44.871 [CM504003]: Sent registration request for 10001@NexVortex
17:09:44.575 [EC200002]: Media server is connected: application
olly:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:56951
17:09:44.497 [EC200005]: Parking Orbit server is connected: application
olly:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:56950
17:09:44.450 [EC200004]: IVR server is connected: application
olly:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:56947
17:09:44.372 [EC200006]: Conference server is connected: application
olly:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:56945
17:09:43.764 [CM506005]: Public IP=97.79.XX.XXX is used for WAN communications through local interface with IP=192.168.0.250
17:09:42.718 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
17:09:42.718 [CM501006]: Default Local IP address: [192.168.0.250]
17:09:42.718 [CM501002]: Version: 9.0.15776.0
17:09:42.718 [CM501001]: Start 3CX PhoneSystem Call Manager
17:09:42.718 [CM501007]: *** Started Calls Controller thread ***
17:09:42.594 [EC200001]: Configuration server is connected: application
olly:5485/DBProvider local:127.0.0.1:56942 remote:127.0.0.1:5485
17:09:42.578 [CM501010]: License Info: Load Failed
What is interesting here is that the license failed to load. While the 888 fax extension is shown to be registered by 3CX in the log and in the system extension status page, a call to the DID number gives a playback indicating the that service is not registered. Further, the conference extensions and shared park extensions also show as not registered. All the 3CX services show to be started in both 3CX and Windows Server 2008 Services. I assume the software has implemented the free addition attributes as a result of not being able to load the license info. I then killed them all and restarted again while the NIC was disabled and the same results.
I then renabled the second NIC and all started up upon a restart all. However, as you can see, 3CX picked up the second NIC card....again.
Following is the log.
17:32:58.598 [CM504001]: Ext.118: new contact is registered. Contact(s): [sip:
17:32:44.287 [CM504001]: Ext.102: new contact is registered. Contact(s): [sip:
17:32:36.070 [CM504001]: Ext.106: new contact is registered. Contact(s): [sip:
[email protected]:5060/106]
17:32:33.802 [CM504001]: Ext.105: new contact is registered. Contact(s): [sip:
[email protected]:5060/105]
17:32:29.335 [CM504001]: Ext.MakeCall: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=f69e732b3f3248aa/MakeCall]
17:32:29.334 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=3b00e63a2229a2fa/IVRForward]
17:32:29.321 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=c42e071523fe35e2/EndCall]
17:32:29.312 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=3bd7041913e5d8ab/800]
17:32:29.199 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:
[email protected]:40600;rinstance=1879b2c9bd97287e/999]
17:32:07.086 [CM504004]: Registration succeeded for: 10001@NexVortex
17:32:06.739 [CM504003]: Sent registration request for 10001@NexVortex
17:32:06.635 IP(s) added:[192.168.20.250,192.168.0.250]
17:32:04.560 [CM504001]: Ext.SP9: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=0576b430607fdbb6/SP9]
17:32:04.560 [CM504001]: Ext.SP8: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=e78c223278eaeab5/SP8]
17:32:04.559 [CM504001]: Ext.SP7: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=4764bf064e08f297/SP7]
17:32:04.558 [CM504001]: Ext.SP6: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=50af06e8b3579bcf/SP6]
17:32:04.545 [CM504001]: Ext.SP5: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=c254a64c684bf152/SP5]
17:32:04.525 [CM504001]: Ext.SP4: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=fb318658291ba2c2/SP4]
17:32:04.513 [CM504001]: Ext.SP3: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=d03e3535fecad60f/SP3]
17:32:04.424 [CM504001]: Ext.SP2: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=46a180be52fa7937/SP2]
17:32:04.423 [CM504001]: Ext.SP1: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=36e7e1c69bfec016/SP1]
17:32:04.422 [CM504001]: Ext.SP0: new contact is registered. Contact(s): [sip:
[email protected]:40000;rinstance=36e782e83b7e6baf/SP0]
17:32:04.410 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=6edba88e24795027/*1]
17:32:04.397 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=61c73aaa0091b9da/*0]
17:32:04.388 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*
[email protected]:40000;rinstance=1fc75af7538afe81/*777]
17:32:04.365 [CM504001]: Ext.704: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=85c89556a88e742b/704]
17:32:04.329 [CM504001]: Ext.703: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=c2fb28e603e80570/703]
17:32:04.328 [CM504001]: Ext.702: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=a732292cc0e3d7a6/702]
17:32:04.315 [CM504001]: Ext.701: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=198ca78873bbadbc/701]
17:32:04.307 [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:
[email protected]:40300;rinstance=fcc9d960e68a34ee/700]
17:31:59.461 [EC100007]: External application is connected: application
olly:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:57596
17:31:58.990 [CM504004]: Registration succeeded for: 10001@NexVortex
17:31:58.844 [CM504008]: Fax Service: registered as sip:
17:31:58.703 [CM504003]: Sent registration request for 10001@NexVortex
17:31:58.336 [EC200002]: Media server is connected: application
olly:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:57592
17:31:58.284 [EC200005]: Parking Orbit server is connected: application
olly:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:57591
17:31:58.214 [EC200004]: IVR server is connected: application
olly:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:57588
17:31:58.137 [EC200006]: Conference server is connected: application
olly:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:57586
17:31:57.599 [CM506005]: Public IP=97.79.xxx.xxx is used for WAN communications through local interface with IP=192.168.0.250
17:31:56.545 Failed to obtain short path name for [C:\ProgramData\3CX\Bin\Cert]
17:31:56.545 [CM501006]: Default Local IP address: [192.168.20.250, 192.168.0.250]
17:31:56.544 [CM501002]: Version: 9.0.15776.0
17:31:56.544 [CM501001]: Start 3CX PhoneSystem Call Manager
17:31:56.544 [CM501007]: *** Started Calls Controller thread ***
17:31:56.421 [EC200001]: Configuration server is connected: application
olly:5485/DBProvider local:127.0.0.1:57581 remote:127.0.0.1:5485
17:31:56.406 [CM501009]: License Info: Loaded Succeeded
