Fax-Server settings G.711 fallback checkbox state not correct
Discussion in '3CX Phone System - General' started by Severin Meyer, Mar 24, 2018.
  1. Severin Meyer
    Jul 29, 2017
    53
    If the parameter FAX_PCMU_T38_FALLBACK_TIMEOUT is changed to a value other than 10, the checkbox under Fax-Server settings is not checked.
    The checkbox should be checked if FAX_PCMU_T38_FALLBACK_TIMEOUT > 0.
    Much better, the value for the timeout should be displayed beside the checkbox.
