Fax Server v15
Discussion in '3CX Phone System - General' started by complex1, Oct 15, 2016.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    After upgrade from v14 to v15 SP2 the fax number of the build in Fax Server gives always busy sound.
    All services are running.
    Are there some extra settings in v15 I missed?
    Thank you for your assistance.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    I upgraded from V14 to V5 a week or so after it came out. I also did the SP1 update when it came out and finally SP2 last week. In each upgrade I have not had to do anything with regard to the fax. It has worked in each iteration and as far as I know, there are no special settings needed.
  3. 3cxsbx
    Nov 18, 2015
    28
    @complex 1
    * be advised that if you upgraded to v15 linux the fax server is not there yet.
    * if you use windows it will surely be a different story.
