FAX service is stuck at "stopping" status
Discussion in '3CX Phone System - General' started by petselas, Feb 21, 2011.
  1. petselas
    Sep 7, 2010
    7
    Hi all,
    I try to run Firewall Check and when I tried to sto Fax servise it stucked at "stooping" status.
    Anyone can help on this ?
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Open task manager and kill the 3cx fax process.
  3. petselas
    Sep 7, 2010
    7
    You mean the windows task manager ?
  4. abc123
    Nov 9, 2009
    712
    yes
