Fax Service Patton not passing to Fax Service
Discussion in '3CX Phone System - General' started by nmacbradaigh, Dec 7, 2009.
  1. nmacbradaigh
    Nov 30, 2009
    I a Patton 4960 and running 3Cx version 7.1.6. The Patton has some DDI and all are working except the Fax. This has been working I updated to version 8 it stopped working so I downgraded back to version 7.1.6.
    Here is a copy of the logs for a Fax Call
    16:48:23.684 [MS105000] C:228.2: No RTP packets were received:remoteAddr=192.200.9.8:10004,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7266
    16:48:23.684 [CM503008]: Call(228): Call is terminated
    16:48:23.669 [CM503008]: Call(228): Call is terminated
    16:48:22.466 [CM503007]: Call(228): Device joined: sip:888@192.200.9.8:5100;user=phone
    16:48:22.466 [CM503007]: Call(228): Device joined: sip:anonymous@192.200.9.149:5060
    16:48:22.450 [CM503002]: Call(228): Alerting sip:888@192.200.9.8:5100;user=phone
    16:48:22.388 [CM503004]: Call(228): Calling: @[Dev:sip:888@192.200.9.8:5100;user=phone]
    16:48:22.372 [CM503010]: Making route(s) to <sip:101@192.200.9.8:5060;user=fax>
    16:48:22.356 [CM503001]: Call(228): Incoming call from anonymous@(Ln.10000@FRA) to <sip:101@192.200.9.8:5060;user=fax>
    16:48:22.356 [CM503012]: Inbound office hours rule (CC Fax) for 10000 forwards to Fax:101
    16:48:10.763 [CM504008]: Fax Service: registered as sip:888@192.200.9.8:5060 with contact sip:888@192.200.9.8:5100;user=phone
    I have reloaded the Patton, redid its config from scratch. The DDI are working as if I change the Fax to voice line the number works fine.
