FAX Service problem
Discussion in '3CX Phone System - General' started by chisel900, Mar 28, 2013.
  1. chisel900
    Mar 11, 2013
    10
    Ever since the update to v11 our fax service has been playing up when trying to receive faxes . If I try and dial the fax DDI number it connects to the 888 extension ok but there is no tell tell beep sound. If I then re-start the FAX service from the management console then try and dial the FAX line it works. The problem is it only works for a short while then stops again. When we were using version 10 of the 3CX software we had no issues at all. Can anyone shed some light on what may have changed?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please provide server log of problematic call?
  3. chisel900
    Mar 11, 2013
    10
    Hi Stepan,
    I dialled the fax line from my mobile and then took a snapshot of the log and I got the following:
    • 02-Apr-2013 09:13:09.215 [CM503007]: Call(C:4232): Extn:128 has joined, contact <sip:128@192.168.1.128:5060>
      02-Apr-2013 09:13:09.213 [CM503007]: Call(C:4232): Line:10000<<*********** has joined, contact <sip:44***********@spitfiretsp.net:5060>
      02-Apr-2013 09:13:09.211 L:4232.2[Extn] has joined to L:4232.1[Line:10000<<***********]
      02-Apr-2013 09:13:01.484 [CM503025]: Call(C:4232): Calling T:Extn:128@[Dev:sip:128@192.168.1.128:5060;transport=udp] for L:4232.1[Line:10000<<***********]
      02-Apr-2013 09:13:01.439 [CM503027]: Call(C:4232): From: Line:10000<<*********** (<sip:***********@192.168.1.37:5060>) to T:Extn:128@[Dev:sip:128@192.168.1.128:5060;transport=udp]
      02-Apr-2013 09:13:01.438 [CM503004]: Call(C:4232): Route 1: from L:4232.1[Line:10000<<***********] to T:Extn:128@[Dev:sip:128@192.168.1.128:5060;transport=udp]
      02-Apr-2013 09:13:01.438 [CM505003]: Provider:[Spitfire] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NFeDhrsNdk4d6BG] PBX contact: [sip:44***********@192.168.1.155:5060]
      02-Apr-2013 09:13:01.435 [CM503001]: Call(C:4232): Incoming call from Line:10000<<*********** to <sip:128@192.168.1.155:5060>
      02-Apr-2013 09:13:01.434 Line limit check: Current # of calls for line Lc:10000(@Spitfire[<sip:44***********@spitfiretsp.net:5060>]) is 2; limit is 10
      02-Apr-2013 09:13:01.429 [CM503012]: Inbound any hours rule (unnamed) for 10000 forwards to DN:128
      02-Apr-2013 09:12:57.943 Currently active calls - 1: [4231]
      02-Apr-2013 09:12:52.382 [MS004000] C:4231.2: (ACTIVE): Can't send RTP stream to 127.0.0.1:10002 destination unreachable
      02-Apr-2013 09:12:52.376 [CM503007]: Call(C:4231): Fax:888 has joined, contact <sip:888@127.0.0.1:5100>
      02-Apr-2013 09:12:52.374 [CM503007]: Call(C:4231): Line:10000<<*********** has joined, contact <sip:44***********@spitfiretsp.net:5060>
      02-Apr-2013 09:12:52.372 L:4231.2[Fax] has joined to L:4231.1[Line:10000<<07415375993]
      02-Apr-2013 09:12:52.307 [CM503025]: Call(C:4231): Calling T:Fax:888@[Dev:sip:888@127.0.0.1:5100;user=phone] for L:4231.1[Line:10000<<***********]
      02-Apr-2013 09:12:52.274 [CM503027]: Call(C:4231): From: Line:10000<<*********** ("Fax:" <sip:***********@192.168.1.37:5060>) to T:Fax:888@[Dev:sip:888@127.0.0.1:5100;user=phone]
      02-Apr-2013 09:12:52.274 [CM503004]: Call(C:4231): Route 1: from L:4231.1[Line:10000<<***********] to T:Fax:888@[Dev:sip:888@127.0.0.1:5100;user=phone]
      02-Apr-2013 09:12:52.274 [CM505003]: Provider:[Spitfire] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [NFeDhrsNdk4d6BG] PBX contact: [sip:44***********@192.168.1.155:5060]
      02-Apr-2013 09:12:52.258 [CM503001]: Call(C:4231): Incoming call from Line:10000<<*********** to <sip:888@192.168.1.155:5060>
      02-Apr-2013 09:12:52.258 Line limit check: Current # of calls for line Lc:10000(@Spitfire[<sip:44*************@spitfiretsp.net:5060>]) is 1; limit is 10
      02-Apr-2013 09:12:52.253 [CM503012]: Inbound any hours rule (Fax) for 10000 forwards to Fax:888
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    @chisel900
    The log messages you posted do not show any cause for the failure. If you have access to 3CX Support, you should open a support ticket for further investigation into this issue.
