Fax service
Discussion in '3CX Phone System - General' started by novastar, Feb 21, 2008.
  1. novastar
    Jul 16, 2007
    15
    PLEASEEEEEEEE fix this annoying fax-issue:
    19:25:43.218 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.2:5100;user=phone
    19:25:42.218 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    19:15:42.890 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.2:5100;user=phone
    19:15:42.078 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    ETCETERA ETCETERA ETCETERA
    This has been reported so many times and it's not solved yet.
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    I ended up stopping the fax service as it was not needed
    Stephen
  3. novastar
    Jul 16, 2007
    15
    That's an option, but should not be needed imho...
  4. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    I found in technical manual that it is NORMAL behavior.
